LS1 Hot Cam Feedback Still trying to pick a cam LOTS OF Questions
Im still trying to think of what I want to do but I think its going to be the hot cam.anyone have sound clips of it or are running it that has any feedback on it.Heres the mods I have right now 3500 stall 3.73s,lca,ported TB and MAF,TB By pass,Air Lid,All Free mods.The only thing I would be changing in the future are long tubes,LS6 intake,timing change,underdrive pulley,oil pump.
also have what in sign.what im looking for is something to change the sound a little I dont want the real lumpy sound but just a little change and I would like to pick up as much track time as I can what do you guys recommend.I will have stock heads and wont be changing them.Hope someone can help thanks
If you do a search you will find many threads debating the pro's and con's of the HotCam vis a vis other cams. I love my HotCam - it sounds great and I gained 39 RWHP with it (plus tuning and a ported TB).
It all depends on what you want to acheive and the money you're willing to spend. The HotCam suited my needs/driving habits/budget perfectly. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Good luck with your search <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
-Bradster <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
I know there are better performance cams than the Hot Cam out there, but for me, this is the one. First off, it's a GM part. Second, It's relatively cheap. Third, it sounds nasty. And fourth, it gives a pretty decent "bang for the buck".
Those are pretty much my simple reasons for purchasing this cam (prolly this spring.
Has anyone had any major problems with this cam? Any imput would be appreciated.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I had the hotcam in my Trans Am.Sounded cool made good power untuned and the car was really fast with it.Made 358hp and 353lb/ft tq at the wheels.Car ran a best of 12.33@114.52 in August.Im a big fan of this cam,thinking about putting it back.
I guess my hotcam didn't do so shabby either. It's went 11.3@120 on motor. Check sig for more details.
How is the Idle with the Hotcam? I'm torn between Picking up the Hotcam or the LS6 Cam for my New baby arriving next week.
I just ordered the Hotcam yesterday from SDPC <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" /> <img border="0" alt="[gruffy cottonball]" title="" src="graemlins/gr_gruffy.gif" /> <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
<small>[ February 18, 2003, 04:47 PM: Message edited by: shawn's SS ]</small>
You may need to do some program changes or the TB drill out to address possible choppy idle issues with the 112 LSA on an A4 car. Some A4's can get away without it but that is the exception to the rule. It will idle quite a bit more choppy than an LS6 cam. What's the LSA on that one, somewhere around 115 or so? Personally, do your homework before you decide to go 112 on an A4. You may not like it as much as a 114 or so. I'm sure there are plenty that are running it in A4 cars and they'd be better suited to give you specifics. Good luck! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I have been looking at cams for the past few months and so far from what I have read this is the cam to get for the daily street driven car. The bonuses are, less stress on the valvetrain, I don't know about you but the thought of replacing $200 springs yearly doesn't sit well with me. At .525 lift you can't go wrong. The duration is great for headers and N2O, I have both. I also have a 3500 stall, so it plays well with that. I really can't find anything not good about the cam, just some say it is not big enough, but I wan't day to day driveablility, and this cam seems to offer that without sacrificing it along with reliablility. You still get an excellent boost in power, port the stock head and get even more.I just ordered mine today, SDPC has a great price on this cam with springs, add Titanium retainers for just $85 more, and you can't beat the price.Out the door for just barely over $500.
<small>[ February 17, 2003, 01:54 PM: Message edited by: BigBake ]</small>
well lingenfelter has a cam with the same specs. but has a higher lift. i wanted the higher lift. the gt1 cam specs are 218/228 .560/.560 lift 113lsa and its only 299.99 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
I am also thinking about getting a 'hot cam' for my 2002 M6 Z28. What sort of gains do you think I would see based on the mods I currently have (see dyno sheet). The car runs 111mph on the motor and 118.5mph spraying 3rd and 4th without powershifting. Could I pick up 20-30RWHP or 113-114MPH on the motor? I also heard the cam works well with NOS... what sort of gains do you think I would see with a 100HP dry shot? Thanks!
Andre Avigdor @ www.avigdor.net
<img src="http://solo2.abac.com/avigdor/z28/d6.jpg" alt=" - " />
Anyone know where the "Hotcam" peaks?
Which would make more power @ 6200 RPM the hotcam or the '02 Z-06?
-Nick
-Nick
When I get home from work today I'll dig up my dyno sheet from my hotcam install and check where it peaked for my car (bolt-ons).
I don't think the hotcam's numbers will be too impressive at 6200 rpm - if I remember correctly, it's powerband is pretty flat until right around 5K rpm and then it falls off pretty good after 6K rpm <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
I'll post what the sheet says when i get home <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Raven99:
<strong> When I get home from work today I'll dig up my dyno sheet from my hotcam install and check where it peaked for my car (bolt-ons).
I'll post what the sheet says when i get home <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks!
OK, I got the sheet in front of me (I don't have a scanner at home so I can't post it). The Torque peaked just below 4800 rpm (361 lb/ft). The Horsepower peaked just under 6200 rpm (370.1 RWHP).
The torque curve stays above 350 lb/ft from 3800 rpm and remains pretty flat until just after 5000rpm where it falls off steadily. The horsepower curve is is pretty much a nice arc up to it's peak just before 6200 rpm.
The numbers at 6200rpm: Horsepower is right around 370. Torque has dropped off to roughly 315 lb/ft.
I'll scan it at work tomorrow and post it if you like.One thing - this dyno pull was done with the stock Torque Converter. Since that pull I have installed a Vig 2800 / TransGo & B&M Tranny Cooler. So my car's numbers as it sits today would be different than what that dyno sheet shows. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Hope this helps! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
-Bradster <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
