Engine alarm?
Old 03-19-2009, 05:35 PM
uLs1a's Avatar
Default Engine alarm?
For the past 3 or 4 days when ever I would start my car it would sound a faint alarm, almost like the ringing you get in your ears sometimes. It does it whenever I start the car, or after I come to a stop and when Im about to shut the car off. Anyone have any idea what it could be? I will see if I can get a video of it
Heres the video
Old 03-19-2009, 06:56 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Check and see if it is coming from the left front fender in front of the wheel. If it is then the AIR pump is taking a crap.
My car did this so I took it out and trashed it
Old 03-19-2009, 07:39 PM
uLs1a's Avatar
When you say left fender, you mean passanger side?
Old 03-19-2009, 07:44 PM
joecar's Avatar
No, the other left....
Old 03-19-2009, 08:04 PM
uLs1a's Avatar
Well I checked my left passanger side and that it where the alarm is coming from
Old 03-19-2009, 08:13 PM
King Nothing's Avatar
hahaha i think he meant drivers side near the relay box hmmmm i can't think of anything really over there except maybe the horn
Old 03-19-2009, 08:39 PM
uLs1a's Avatar
Whatever side it is, I have a loud noise coming from the passanger side. Screw it Im gonna go get a video of it
Old 03-19-2009, 09:13 PM
uLs1a's Avatar
Video is up
Old 03-20-2009, 01:24 AM
Z28/2002's Avatar
Left front fender= drivers side
The AIR pump is on that side under the frame rails. You can get to it by using the access panel attached to the bumper
to the OP: I can't view the video due to these government filters blocking everything. Hopefully someone can help you out
Old 03-20-2009, 12:46 PM
uLs1a's Avatar
Its gotta be something else then cause its coming from the passanger side
Old 03-20-2009, 01:01 PM
intake68's Avatar
Keep driving it and what ever it is, it will fall off soon enough
Seriously tho that is quite the whine. It sounds rpm related but seems to go away with load. My first step would be to remove serpentine setup and spin all my accessory drives by hand. My initial guess from the noise is maybe a bearing on AC compressor or the electric clutch on it. Did you try to turn on the AC when the car is at idle making this noise?????
Old 03-20-2009, 01:42 PM
uLs1a's Avatar
I didnt think about the A/C, Im gonna go check it right now
Old 03-20-2009, 01:54 PM
uLs1a's Avatar
Alright I jus drove the car and the whine was gone....
Old 03-20-2009, 02:05 PM
Z28/2002's Avatar
I was just clarifying incase someone was confused about what I was getting at
Old 03-20-2009, 11:29 PM
uLs1a's Avatar
Anyone else have an idea? I heard it a few times tonight
Old 03-21-2009, 12:00 AM
David_viny's Avatar
MAYBE its an idler pulley bearing going bad? Id spray some lube on the bearings of the pulleys and see if it temporarily goes away. Mine are going bad but doesn't sound like that at all though..
Old 03-21-2009, 04:31 AM
Erikz 28's Avatar
Only thing I could think off is the AIR pump too. Is it like the faint sound of a turbo spooling? How long does it last? You're sure it's not belt squeak?
Old 03-21-2009, 02:00 PM
hammertime's Avatar
After watching your video, it sounds like it is directly linked to engine vacuum, but it does come and go as you placed your hand on the throttle body. Has it been off the car before? Check to see if anything is loose around there. Maybe wiggle the cam on the accelerator linkage (without opening it) to see if you have a leak around the TB shaft.
You can try using a length of vacuum hose to isolate where the noise is coming from, just don't get it caught in any of the accessories!
Good luck!
