Cam/Header Install--1 hour into it.
So Far So Good, right now I am trying to get the balancer bolt out, it seems tight as heck, and I don't want to break it. So I sprayed a little PB Blaster on it while I have some lunch. So far I have only used like 5 different tools to get this far into it. Turning out to be pretty fun. Hopefully my lifter tools get here today.
Using all of the great info I have gleaned off of here is helping alot.Later,
Aaron
...make sure you buy a longer bolt when you re-install the pulley....buy it a auto zone...
...use the new longer bolt to "start" the pulley onto the crank....after you have it on about 2/3rds....pull it and install a brand new GM tork-to-yield crank bolt....
....oh yeh, dont tighten the timing cover bolts untill you have the crank pulley installed....this helps to center the cover so the seal does not leak...
If you don’t have a 24mm 6 point 1/2” drive socket; go buy one. DON’T use a 12 point socket on your crank pulley bolt. It does not grab enough meat on the bolt head, and may round off the head as you are trying to remove the ‘Super Tight’ crank bolt. If this happens; YOU WILL have more problems than you would ever want to deal with!!
Sears sells this socket in a deep-well version made for an impact wrench. This is the best one to get. The impact socket is much stronger than a regular socket and will not distort.
Ron,
i used a 3ft breaker bar, and some muscle, keep at it, eventually it will budge....also, make sure you have the right socket, like mentioned above
jimmy
Thanks,
Aaron
Derek
Derek
They are talking about using a 1/8" piece of steel rod with a strip of velcro running along it lengthwise, stick 2 of these rods in the front of the block, and you basically have a homemade lifter tool(does the same thing as the 80$ JPR tool, wich I was silly enough to get.
Hope this helps,
Aaron
