Comp Cams customer service SUCKS!!
I called looking for info on a cam and some springs. I purchased a cam and wanted to know exactly what I have, so I go on to tell him the numbers stamped:
3722R/3722R
HR11
C9221
He was speaking Greek to me and would not give me the time to expain the cut. I dont have much knowledge, hence the purpose of the call. The only thing he told me was I had a lift of 513 on a 1.5 rocker and a lsa of 111. Does this sound right? How do I figure the lift on a 1.7 rocker? I was hoping to get an explanation of just what I have. The cam was bought expecting it to be a 220/220 581/581 on a 112, but sounds a little different to me. Not a big deal, I just want to know.
Then as far as the springs, I told him that I have the 918's with the blue stripe and that I read that Comp was either checking these for weakness or replacing them. He told me that very, very few of the springs have had problems and since I dont have the batch number, I am out of luck.
................... I just wanted to vent. You would think that with the economy the way it is right now, salesman would be doing everything they could to please. Maybe Comp is large enough to not give a **** about the "Typical" customer.
3722R/3722R
HR11
C9221
What exactly were you wanting to find out?
you have .581 lift with 1.7 rockers.
You take the .513 divide that by the rocker arm ratio 1.5.
You get .342 which is the lift at the lobe. You then multiply that by 1.7(your new rocker arm ratio) and you get .581
As far as the LSA being 111 I know cam manufacturers sometime round up. I have seen several threads where people degree there cam and the "shelf" grind number is a little bit off than what it actually is.
I am going to assume, which I shouldn't do, that the 3722R is the lobe number. If you look at their catalog I am sure it would list it. That I can't help you on.
Added. If you don't have the batch number for the springs I don't see how they could help you. Yes I think they did have a bad run of the 918 springs and they got a bad rap for it. How isolated that was I don't know.
I wanted to know the duration at int./exh. and the lift int./exh.
I know now that the 3722R is the lobe number and I think its an XER???
Where did ".513" number come from to begin with?
3722R is an XER lobe. 224 duration @ .050 w/ .581 lift w/ a 1.7 rocker. So your cam is a 224/224 .581/.581 on a 111 lobe separation. The .513 lift comes from the lobe chart, it gives the lift w/ 1.5, 1.6, and 1.7 rockers. Comp's tech line is hit or miss. If you call back you might get someone that knows a bit more about what they are selling.
I tried to look at their catalog but I keep getting an "explorer" error.
Usualy Comp makes cams on 112 or 114 lsa
the person who answers the phone at comp is just a secretary...you have to ask for their tech dept, they are the people to answer our tech questions
LS1Tech Premium Sponsor
But they are correct, it's a 224/224 .581"/.581" 111LSA that you've got.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
HR = Hydraulic Roller
11= 111° LSA or (LCA to some folks)
FWIW, PZ you really didn't know that information? Mark Twain was right. You should read/heed his pithy quotes.
Jon
Go with your gut, Jimmy.
"Question authority." ---Timothy Leary (perhaps)
Jon
They have always been great to me, Ive bought stuff from them since the early 90s without an issue ever.
Put yourself in their shoes for a second, His "Greek" was probably the information you were looking for but you just didn't understand what you needed. I couldn't imagine having a job talking to people like this all day. I'm not pointing you out specifically, but I'm sure they get calls about how to tune, how much timing to run, etc, etc, and very few calls where someone is buying anything.
Thanks for the info.
Thank goodness for the helpfull people on LS1TECH!!!! I should have just come here first, thanks guys.
Comp will grind a cam with any LSA you specify if it will fit on the available cores. They identify the LSA and the type of cam exactly as sandking posted.
Jon
Jon
Not all comp cams have that etched on the back. As a matter of fact, I never order one direct.
This is the kind of info I'm used to: Clearly says HR112
You and your wolf pac can troll around me all you want. To me it only shows that you are a bitter old thing that has to ridicule and pray on others to prove to the world he has amounted to some type of value in life.
You guys were banned from LS1tech for a reason. For similar behavior and always trying to pimp your business without paying the costs. You ridicule this site on hardcorels1, its members, its sponsors, that is what you are good at.
You are like a disease on a monkey's ***, no matter how you look at it, it ain't never good.
I think I understand your behavior in trying to discredit me or some sponsors here all the time. Either it kills you that I help for free or you are so bitter about what the administrators of this site did to you and your son that you want to do your outmost with your followers to hurt it.
As for the sponsors (they know who they are) you just envy their success. Why? because no matter how much you try, you will never build and achieve what they did. You simply have the wrong attitude and you concentrate on the wrong things to achieve that success.
As Mark Twain said "...among human beings jealousy ranks distinctly as a weakness; a trademark of small minds; a property of all small minds, yet a property which even the smallest is ashamed of; and when accused of its possession will lyingly deny it and resent the accusation as an insult."
- Letters from the Earth
I am here to stay and to share info from and to my fellow members. I like Ls1tech.com and unlike you, I am not all knowing (or think that I am) and as long as I am here, I will share what I know, always for free.
I know the purpose of your post Jon.
Thank you for your insight into matters of veterinary medicine, your altruism, your knowledge of my inner motives and your (almost) all knowing grasp of cam lore.
The actual Twain quote I was thinking of was one much better known:
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." --Mark Twain
Jon
Jon
Jon
https://ls1tech.com/forums/11495218-post136.html
Perhaps you should apply that quote to your son....
Nah, I know him better than you do. I'll stick with my original recommendation, but I'll skip the references to your posts. So many posts, so little time.
HC is a lot of fun, ain't it?
Question for you: When you so generously recommend cam specs do you recommend the lobes by number? Who's lobes do you use? There can be quite a few lobes out ther in the ether with the same duration and lobe lift. I've heard that some lobe families act differently from others. Do you recommend associated valvetrain parts to go with your free cam specs? If not, why not? When you recommend a cam do you suggest a supplier? Who?
Jon
He gave me lobe #'s from Comp along with the specs.......
Nobody knows everything including Bret....(i.e. Engine Masters debacle)....
But I have seen your son & Joes (bless his soul) work (T4P 243's) and it was exceptionally nice....Wish I could afford it but 3 kids (college) etc... I have even recommended to some hardcore racers to contact Bret.
Anyway... I don't understand why you are on PZ's *** unless you just don't like the fact he shares his knowledge for no compensation.
I also PM'ed you about exactly what it was about the TSP stuff (that Bret bashes all the time) you thought made it bad/inconsistent (VJ's,port program, QC, etc..) and you didn't reply to the question. And BTW I am not a TSP nutswinger and will have different heads when my 383 goes in.....
And thanks for the compliment on my screen name (from a PM)......only us oldtimers remember Jackie Gleason yelling into the radio to Bandit "you SOMBITCH I'm going to barbecue your ***" One of my alltime fave movies I am a Burt Reynolds fan too......
