Building ls1 block what do i need for boost?
what pistons will you go with? if your using stock displacement pistons i'd go 6.0 heads so you can get your compression ratio in the 9's if your going to knock on the rev limiter a lot i would probabaly go with some really good connecting rods.
have to tell us what YOU want. i know nothing about drifting really. what RPM do you plan to spin to?
the stock rockers will work?? id really hate to use the stock ones and then it fail on me. ..also pushrods what size should i get? its kind of confusing when i was looking them up. thanks for you help
If I were to get a good set of piston, connecting rods and rod bolts, would I be ok on stock compression and running 550rwhp?
wouldn't the thickness of gaskets possibly throw off dementions on rocker arms to need shorter/longer ones?
I figured the pistons would be the number one problem, second rods, correct? I dont wanna change the cam, or touch the heads if I dont need to be. Just build the bottom end.
