Z06 cam push rod question
Old May 18, 2009 | 09:23 PM
mike13's Avatar
Default Z06 cam push rod question
The base circle of the Z06 cam is supposed to be smaller, so everything being equal how much longer push rod would you need if you had a set of 243's without the special length Z06 valve stems?
Old May 19, 2009 | 04:18 AM
PREDATOR-Z's Avatar
Measure.
Old May 19, 2009 | 05:31 AM
vsocks1's Avatar
Need a set of Z06 pushrods? I have a set from 2003 with only 10,000 miles. I need different length for my head/cam project!
Old May 19, 2009 | 08:52 AM
bigboykilroy's Avatar
+1 Measure...every application although similar is different
Old May 19, 2009 | 09:18 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
they won't work for him, they are the same as what he has stock. The difference is in the cam base circle and the valve stem length, with the same pushrod inbetween.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old May 19, 2009 | 09:34 AM
topher455's Avatar
You really should measure. The base circle of the 02 Z06 cam is .050 smaller so usually you will need to get a rod that is .025 longer than stock (all things being equal you would need a 7.425" p-rod) but again you really should measure. Lots of variables can make a difference.
Old May 19, 2009 | 10:51 AM
mike13's Avatar
yes If I install the cam I'll measure I just wanted to know the difference. It's much easier for me to start with a known. So if I started with the stock length keep increasing until it goes past optimum. I just wanted to make sure there was going to be a noticable amount of adjustment.
Old May 19, 2009 | 11:22 AM
topher455's Avatar
Yes .025 is a significant change from stock.
Old May 24, 2009 | 02:04 PM
BandDirector Blk98ZM6's Avatar
I've got the opposite problem I think. I've got an '04 crate LS6 longblock swap in my '98 Z28. If I wanted to go with the TR224 cam, would I need to get shorter pushrods, or can I just put the cam in without changing pushrods?
Old May 24, 2009 | 02:32 PM
willyfastz's Avatar
Restricted User
Measure, and you should never run stock pushrods with a aftermarket cam. I wouldn't even recommend stock pushrods for a stock cam.
Old May 25, 2009 | 11:24 AM
topher455's Avatar
You would want shorter pushrods since the ls6 magic valves are .025 longer than normal ls series valves. But again all engines are different and you should measure to be sure. The 7.375 will get you in the ballpark though.
