Dirt late model
1. cast iron block and heads
2. manual / belt driven fuel pump
3 cubes limited to 362 max (I might fudge a little LOL)
4. Headers?
5. 450+ hp
4. Headers?
5. 450+ hp
Iron heads are the biggest problem I see here. Early truck 5.3s had iron heads, I believe, but I'm not sure how available (cheap) they are. Is porting allowed?
362 cubes is also a problem if you really want to stay legal and use a 6.0L block. 450+ fwhp is not a chore if you don't have a really small carb rule.
What are all the rules? This could be fun!
Jon
ENGINE:
A. 362 cubic inch maximum, including over bore.
B. Any steel crankshaft.
C. Stock stroke.
D. Any steel connecting rods.
E. Stock type pistons, 2 or 4 eyebrow, may be forged.
F. Dry sumps allowed.
ENGINE SETBACK:
A. Full tubular frames – six(6) inches with ½” tolerance.
HEADS:
A. Steel heads. Must be based on OEM design (Chevy, World, Dart, and Pro are OK).
B. 23 degree heads are OK. NO 14 degree heads allowed!
C. Intake and exhaust bolt pattern must match original OEM head.
D. Valve angle and valve spacing must meet OEM specs for the head being used.
E. Steel valves only. Undercut stems permitted. NO titanium valves.
F. Valve stem diameter 11/32 inch minimum for all engines.
G. Maximum valve size: Intake – 2.055 ; Exhaust – 1.625.
H. NO porting or polishing.
I. Three(3) angle racing valve job permitted. Machine cuts only.
J. Any valve springs, retainers, roller rocker arms, and stud girdles allowed.
WEIGHT:
**Steel angle plug heads - 2350 pounds
**Cars with 604 GM Crate Motor - 2300 pounds –
* Cars with 602 GM Crate Motor - 2250 pounds
***It is the driver’s responsibility to have declared weight displayed on left side of roof. ANY car with weight not displayed is subject to disqualification.
CAMSHAFT:
A. Flat tappet only. NO roller cams.
DISTRIBUTOR:
A. Stock type or magneto allowed.
CARBURETOR:
A. 750 CFM maximum.
B. Any intake manifold.
C. Gasoline only.
If you can get passed these issues make sure your at the ci limit cause you will be making some sick power compared to rest of the pack so you will be getting checked out hard
I dont want to tell where I race at just yet. I will tell ya it is Alabama
I was going to suggest you find a 6.0 iron block that is in good shape so you can stay stock bore and stock stroke so you will be 364... only 2ci over. If you get to winning or pulling hard on the competition on the straights, you might get ci checked. Only 2ci over might not throw a flag.
Roller cam, 8mm valve stems, 15 degree aluminum heads, and coil per cylinder ignition with no provisions for a distributor.
It seems to me you are about to go through a whole lotta trouble for them to say "hey, you can't do that".
Good luck with finding the '99-'00 iron 6.0L heads (873 is the casting number), they are very hard to come up with. I got lucky and was able to come up with 2 sets. I seriously doubt any local tech guy is going to know the head is a 15* head, but you can argue that it's a factory mass-produced head and maybe get by with it. As for the valve stem rule, it's no big deal for a machine shop to replace the 8mm guides with some 11/32 guides, just measure the stock valve length and get some new stainless valves in that length and then you'll be able to use standard old-style keepers and retainers when you assemble the heads.
If you go iron-block 5.7L like I'm doing, you'll be under the c.i. limit, I'm going just a few thou. over the stock 5.7 size (piston measures 3.902) so it's only going to be about 347-348ci. We're able to use aluminum heads here but with 25lbs added in front of the motor plate as a penalty, so I'm going to use a set of the DART 225 runner heads on mine. We're turning about 4500-5000rpm at corner exit so we should be right at the beginning of the powerband of the motor with DART heads and the solid roller cam we got spec'd out. Looking at about 76-7800 at the end of the straights.
Good luck if you decide to go this route, but get ready for some sticker shock when you start buying the front end parts for this thing, I've got a lot of $$ wrapped up in just the front distributor mount, water pump, and ATI damper. But luckily these things aren't really "wear" items on the motor and I'll be able to use them for a long time.
If this deal turns out to be a pretty nice motor we're going to run it about the last half of this season and then over the off-season swap out the crank and pistons and build a 383 out of it. Then we'll really be able to have some fun.
http://store.summitracing.com/partde...9&autoview=sku
using the 6.0 block will allow the use of the gm 99-00 iron heads.
u will be 330-332ci range with .030 overbore
