A Flooded Street vs. LS1
Old May 28, 2009 | 06:36 PM
WS7_FORMULA's Avatar
Originally Posted by vettenuts
I would personally turn it over by hand if you can then use the starter to blow out the water. Then squirt a little oil in each cylinder to lubricate and turn it over with the starter again to ensure it doesn't start dry. You need to do this quick, the internal parts rust quickly.
turn what over by hand???
Old May 28, 2009 | 06:44 PM
BIG_MIKE2005's Avatar
Good lord, the engine son the engine. What else would you turn over? The entire car? I mean come on man, we are tryin to help, told you exactly what to do & your still not understanding or listening one of the two.
The things we have told you to do is pretty much all you can do once you suck water in the engine. Follow the steps that have been outlined more than once in here & then tell us what happened.
I will say again do not crank the motor with the plugs in it if you know you sucked water in. I'd bet there is water in your cylinders & if you crank it over your gonna hydro lock it probably.
Old May 28, 2009 | 06:59 PM
NemeSS's Avatar
take off acc. belt,
remove plugs
spray wd40 in each cylinder
turn by hand with 24mm socket and breaker bar or large 1/2in. ratchet
turn over a few revolutions
thats what turn over means
Old May 28, 2009 | 07:25 PM
blkdkz28's Avatar
good luck bro I did the same thing on saturday but i was goin a little quicker and threw a couple rods out the block. I am NEVER installing an slp air dam again.
Old May 28, 2009 | 08:59 PM
LS1CMR's Avatar
happened to me in 04 when hurricane ivan passed through atlanta, only thing was that my dumass actually tried to start it after it died (wasnt thinking) and because water will not compress i threw #7 through the block, destroyed the starter, flywheel, engine toast.
Old May 28, 2009 | 09:04 PM
thats insane. Sorry BIG MIKE for giving you a hard time...Im going to start this newbie operation.
Old May 28, 2009 | 10:01 PM
LS1CMR's Avatar
nature is powerful, water has a lot of destructive force
Old May 28, 2009 | 10:03 PM
Sharpe's Avatar
Originally Posted by 00SS6spd
What they're telling you to do in a nutshell is:
Step 1: Remove all 8 spark plugs from your motor
Step 2: Remove the fuel pump fuse from the fuse panel inside the engine bay
Step 3: Turn the key as if you were trying to start your car, and let it crank for 10-15 seconds to pump out any water.
Step 4: Change your oil
Step 5: Install new spark plugs
Step 6: Check/clean air filter, MAF, IAT... And any other sensors that could've gotten wet.
Step 7: Reinstall fuel pump fuse
Step 8: Go to fire it up and hope for the best
Good advice.
01ssreda4's Avatar
I agree completely, no chance in risking it.
Old May 29, 2009 | 06:06 AM
No problem man. The more time you spend on here the more knowledge you'll grow. Granted there is alot of false info, but after a while you figure out which members to listen to & it gets easier.
I hope by now you have got the water out of the cylinders. You do not want it sitting in there very long.
Old May 29, 2009 | 10:22 AM
99LS6SS's Avatar
Same thing happend to me a month after I bought my car...threw #7 outta the block. I had like almost 2 gallons of water in my intake too. I told insurance that they can either buy me a brand new motor or total it out and I will buy a new one. They told me they wanted to stick somethin in my car outta a junk yard and I told the hell no they weren't. So they totaled it.
Old May 29, 2009 | 10:41 AM
  #32
TORCHD 02 TA's Avatar
I know to listen to you
How is your switch panel ocming along
Sorry for the
Old May 29, 2009 | 11:26 AM
  #33
Sorry for the
LOL, PM sent homie.
Old May 29, 2009 | 11:28 AM
  #34
Chrome355z's Avatar
Dude call a mechanic or a friend. There's too much on the line if you don't get the water out of the cylinders...
Old May 29, 2009 | 11:39 AM
  #35
WS6TransAm01's Avatar
CARTEK Racing
Originally Posted by NemeSS
take off acc. belt,
remove plugs
with this guy I think we need to make sure to tell him to have the car in Nutral when turnign the motor over by hand.
I agree with everything said. Turn it over by hand to see if water is coming out the spark plug holes... keep turning it until you do not see any more water coming out. Then crank it using the starter w/o plugs and fuel like the other guys mentioned...
cross your fingers and hope you shut the car down in time, before water got in a running motor.
Old May 29, 2009 | 11:41 AM
  #36
Daryn's Avatar
Formerly darynC-10/23/10
if it sits for more than 7 hours. rust is already forming. . put a 50/50 mix (a little less than a teaspoon) of brake fluid and trans fluid in your cylnders. to help lube it up
Old May 29, 2009 | 02:45 PM
  #37
now I drained the oil pan and water came out first and then oil... and then took out the spark plugs and turned the motor manually and water came out too.....
should i continue doin it manually or buy oil and do it with ignition...*no oil in the engine, so I figured I can't crank it until I put oil again*
Old May 29, 2009 | 02:46 PM
  #38
brake fluid with trans fluid or WD40 like someone mentiioned above.......?
Old May 29, 2009 | 02:54 PM
  #39
I'd put some new oil in it & crank it over some more without the plugs in it. Then drain the oil again & refill. That should clean out any water moisture in you oiling system. After that I'd leave the plugs out & crank it over with the ignition to get any left over water outta the cylinder. Once you believe it's no longer got any water in it then you should be able to put the plugs/fuses back in & try to fire it up.
Old May 29, 2009 | 03:01 PM
  #40
so I will put oil 2 times...one for the crank and the other final for my 3 month oil...is that correct?
