A Flooded Street vs. LS1
Old May 29, 2009 | 03:05 PM
  #41
BIG_MIKE2005's Avatar
I would just to make sure the bearings stay lubricated especially since you found water in the pan. I know it sounds like a pain in the *** but it's cheaper insurance than fubarin a bearing & having to rebuild b/c of it.
And I'd highly suggest against WD-40 in the cylinders. Something about that doesn't sound like it would be bearing friendly if it made it there.
  #42
WS7_FORMULA's Avatar
can I put a cheaper but good oil and then the next refill Ill put the one I use?
Old May 29, 2009 | 03:07 PM
  #43
yea...it sounded odd....so I dont put anything in the cylinders...? just leave it like that
Old May 29, 2009 | 03:23 PM
  #44
Yea, just use some cheap 10w 30. Your not gonna be using it under load & heat like if the engine was running, you just want good lubrication on your bearings.
Old May 29, 2009 | 03:27 PM
  #45
TORCHD 02 TA's Avatar
I use 5W30
Old May 29, 2009 | 04:05 PM
  #46
Soul TKR's Avatar
everything makes total since to me as to what others have said... cept for the "turning over" part... if he has no plugs in it, won't that stop the engine from turning over? I mean, if there's no spark, there's no explosion/compression in the combustion chamber, meaning nothing happening... I've never done this before, but I'm as confused as the newbie
I'll go hide now...
Old May 29, 2009 | 04:27 PM
  #47
05 GSXR 1XXX's Avatar
i was about to ask the same question with cheaper oil. i see no reason to spend 6$ a qt when you can get some cheap **** to run a few min, drain, reapeat several times...
honestly if it were me id flush the hell out that motor!, take the covers off dump loads of oil.. drain pan...
you dont get all that water out... thats going to be $$ to fix!
i hope everyhting works out for you bro!
report back on what happends
Old May 29, 2009 | 04:34 PM
  #48
Yeah I am with you. I would take some cheap oil pour about 12 qtsi nto my valve covers and let it all drain for like an hour. Then fill it back up with some godd synthetic fluid.. Start it let it run for about 15 mins or so. Drain that again and refill.. Might be expensive, but sure beats putting in a new motor
  #49
Rddragon's Avatar
If I was doing it I would also unplug the coil packs from the computer so they do not arch to eachother. I know it would be rare to arch that far but no longer than it takes to unplug the coils, you might as well do it.
Old May 29, 2009 | 06:16 PM
  #50
Mike94ZLT1's Avatar
Originally Posted by WS7_FORMULA
pull what plugs? and turn what over?
Oh Jesus... step away from the car...
Old May 29, 2009 | 06:31 PM
  #51
david068513's Avatar
where do you live? what town and state? maybe someone from here can come help you out with this since most of us have done this before.
good luck and I hope your motor is ok. Make sure you get all that water out and I mean ALL before you start it or you WILL need a knew engine.
Old May 29, 2009 | 09:10 PM
  #52
L SS 1's Avatar
They mean turn over using just the starter motor, its going to spin the crank and the pistons will travel pushing out the water thru the spark plug holes. Obviously its not going to start,the point is to get the water out. I would also spray something like sta-bil fogging oil into the cylinders,no the gas treatment but the spray used when storing a car for long periods.
Old May 29, 2009 | 09:18 PM
  #53
slayerized6's Avatar
pull the plugs, turn the crank over by hand, and spray wd40 through the sparkplug hole (this will displace the water that didnt come out)
Old May 29, 2009 | 11:53 PM
  #54
Daryn's Avatar
Formerly darynC-10/23/10
50/50 mix of transfluid and brake fluid. less than a teaspoon per cylnder.
Old May 29, 2009 | 11:54 PM
  #55
My formy resurrected!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 30, 2009 | 12:34 AM
  #56
Daryn's Avatar
WOO . does it smoke on startup now?
the brake fluid and trans fluid would fix that kinda
Old May 30, 2009 | 01:04 AM
  #57
I highly doubt it...I checked my exhaust and seemed fine...it was too dark to see...but I will be turning it on tomorrow again....Im a bit nervous haha.
I worked my butt off really tough...I don't think I did a bad job for being the first time I changed spark plugs and undrowing a motor...hope everything goes well after this...
thank you all...could've have done it without you...LS1TECH RULES!!!!!!
Old May 30, 2009 | 03:42 AM
  #58
Sid447's Avatar
Smile
Vote of thanks,
to all positive contributors, especially to "BIG_MIKE2005" and "00SS6SPD" for doing most of the sensible steering in this thread.
As an option in a situation like this a couple of gallons of cheapo engine oil (or even flushing oil!) mixed 70/30 with kerosene is great for flushing any crap, including water out of an engine.
As is pulling every electrical connector you can find and spraying a water dispersant (e.g.WD40) into the plug and re-connecting.
If the maf-sensor is suspect and needs specialist cleaning just leave it un-plugged until you get the appropriate cleaner -the car will run in back-up mode.
SS
Old May 30, 2009 | 08:27 AM
  #59
Glad to hear it's running. Now report back after driving it for a while & watch your oil pressure closely. If it kinda moves around while steady cruising thats not good.
Old May 30, 2009 | 11:11 AM
  #60
I will cruise around in a bit...what exactly is the flushing of motor oil...what do I need to do that?
