help!! just installed a ms3, oil pump, timing chain, tuned by tsp
Old 06-07-2009, 11:47 AM
bad98camaro's Avatar
Exclamation help!! just installed a ms3, oil pump, timing chain, tuned by tsp
at times its hard to start, it cranks and cranks then it starts when it start the idle jumps up and down after a while it stops,
Old 06-07-2009, 11:52 AM
5.3litre's Avatar
Need many more details. Does it misfire any? How does it run going down the road? Was it a mail order tune or was it dyno tuned?
Old 06-07-2009, 12:10 PM
no misfire, 2 front o2s r sitting off a code, it runs good, it was mailed in
XZ28X's Avatar
you should try talking to tsp first if they tuned it. Give them the chance to make it right.
Old 06-07-2009, 12:53 PM
5.3litre's Avatar
There's your problem probaly. It's a mail tune. Yea i would talk to tsp or why not just take it to a local shop and have it dyno tuned?
Old 06-07-2009, 12:59 PM
'02 WS6's Avatar
Get it street or dyno tuned by someone local. No mail ins.
Old 06-07-2009, 01:12 PM
Fbodyjunkie06's Avatar
No matter the shop mail ins are usually just enough to get your car started. No more. As others have said get someone local with EFIlive or HPtuners on their lap-top to tune it or take it to a performance shop and have it dyno tuned there.
Old 06-07-2009, 01:26 PM
I'll check out nelson performance they have HPtuners
Old 06-07-2009, 01:38 PM
LS199CAMAROZ28's Avatar
is it just hard to start when its hot or all the time?
Old 06-07-2009, 01:40 PM
some times after it dies out
Old 06-07-2009, 01:59 PM
my ms3 is hard to start when its hot due to iat sensor heat soaking. sounds like you need to adjust the throttle blade alittle to get your iac back in range. cant really do that without any tuning software though. as many ms3 cars as TSP has tuned i'm sure the mail order is close but there are certain drivability issues that are better dealt with in person.
Old 06-07-2009, 04:07 PM
i have a 85mm bbk throttle body. it ildes about 800 to 900
Old 06-07-2009, 04:27 PM
Cape T/A's Avatar
Dont do any adjusting on your throttle body, i have a ms3 in my car and a mail order tune from TSP and it does the same thing, the tune sucks, but i knew it would. It is just tempotary until i get my motor broke in to do a dyno tune. A hand held programmer is a waste of time and money. GET A DYNO TUNE BY A PROFESSIONAL! you will regret doing anything else.
Old 06-07-2009, 04:46 PM
theinstag8r's Avatar
Me three, have to give it a little throttle when hot to start. Getting a dyno tune as soon as my motor is broken in
Old 06-07-2009, 05:03 PM
WS6RED2002TA's Avatar
I know that TSP can tune cars because they have done plenty of them before. However when they tuned my car and it was horrible to drive and I have a little vrx2. I contacted Ron at vengenace and mike hooked my up with a mail order tune that was about 95% dead on. Keep in mind that my car was dyno tuned by Jason at TSP. I am not talking bad about there shop just my experience.
Old 06-07-2009, 05:09 PM
05 GSXR 1XXX's Avatar
drive it up to tsp and just let them tune it...
Old 06-07-2009, 05:46 PM
is it ok to run it at the track. what # will it run at the track
mods on car
ms3 long tube headers ls6 intake k&n cold air intake 85mm throttle body slp loud mouth 3000 stall level 3 from performabuilt trans
Old 06-07-2009, 09:50 PM
Cape T/A's Avatar
I wouldn't run a car full throttle with that amount of mods without a dyno tune. Thats just not worth it to me to risk damage to the engine.
Old 06-11-2009, 02:00 PM
went to the track and ran a 13.054 is that good for what i have on the car. i still need to dyno tune it.
Old 06-11-2009, 02:12 PM
Bad Blue WS6's Avatar
??? hell,, when my car was stock,, the original owner of the car ran a 13.06 ,,, tune that bad boy up and you'll be tearin it up then!!!
