Matching a Streetsweeper cam with the correct head
Old Jun 21, 2009 | 02:03 PM
Don Nguyen's Avatar
Default Matching a Streetsweeper cam with the correct head
I am trying to do my research on how to get my 98 LS1 as close to the +450rwhp range as possible.
I think the streetsweeper cam will help me get there, as well as maintain streetability, but at the same time still providing good power all over the rev range.
The car will also be used as a road coarse track car, in addition to be driven on the street. Would the standard streetsweeper 236/240 cam or the streetsweeper HT 228/232 cam be better suited for my needs? Sorry, I have just started trying to learn about the int/exh numbers for cams, and don't really know how to interpret everything yet.
As far as heads goes, it seems like the AFR 205s are a popular choice. However, are there any other options out there that could possibly do almost as good of a job, but for a lower price?
-Don
Old Jun 21, 2009 | 02:20 PM
LS1Formulation's Avatar
I've got CNC ported 241s and will soon be rebuilding my engine with a streetsweeper 228/232. I should be close to 450 at the wheels, I think. I was already trapping close to 119 with a TR224 before on a mail order tune. If you want power throughout your powerband, get the smaller of the two. Remember, you're only feeding 346 cubic inches. A big cam will be a dog down low and not much fun to drive. I'd say a set of CNC ported 243 heads milled to give you about 11:1 compression plus the 228/232 should easily give you 450 at the wheels. No need to spend the money on AFRs.
Old Jun 21, 2009 | 06:05 PM
vettenuts's Avatar
Contact Ed at FTI, he can recommend a head since the Street Sweeper is his cam design. I know he recommends the AFR's but it may also depend on what you are looking for. He also has other street sweepers, we installed a 220/224 in a friends car and it worked out very well and may better fit what your are looking for on the track coming out of corners.
Old Jun 21, 2009 | 06:09 PM
sixpack_2_go's Avatar
you might check out trickflow 215 or "as cast" heads. they seem to put out great numbers
Old Jun 22, 2009 | 09:22 AM
eamador11's Avatar
The 228/232 cam at 114LSA would be better for your needs. It will match up real nice with the AFR 205s.
Old Jun 22, 2009 | 11:41 AM
Don Nguyen's Avatar
What's the reasoning behind that one
-Don
Old Jun 22, 2009 | 12:21 PM
Honda Nick's Avatar
I made 445 whp with a MS4 cam, PRC 215 heads, LS6 manifold and a heavy/built drivetrain.
Old Jun 22, 2009 | 03:29 PM
AznMuscle's Avatar
+1 Ed knows his ****. I was originally going to go with a Street Sweeper design, but instead I have a Toxic. I love this cam.
Old Jun 22, 2009 | 03:32 PM
Don Nguyen's Avatar
Looks like I will have to contact a vendor/sponsor who carries everything I am looking for, in order to optimize the package and possibly give me a group discount/purchase on all of the items.
I may be looking at getting a FAST 92/92 intake and TB (possibly get them further ported as well), Streetsweeper-ht cam, afr 205 heads (haven't decided on this yet), and I need to look at possible local tuners if there are any.
-Don
Old Jun 22, 2009 | 03:33 PM
Don Nguyen's Avatar
What made you end up switching your choice? Did Ed recommend you something else, based on your needs?
-Don
Old Jun 22, 2009 | 03:34 PM
AznMuscle's Avatar
Guy out here has some custom grinds that Ed does for him. I talked to him since I wanted a "big" cam, and Ed got everything together with the valvetrain, and had comp grind the cam. Ask Ed about the AZPS cams...01, 02, and 03 (what I have).
Old Jun 22, 2009 | 04:48 PM
kenp's Avatar
Here is a combo New Era put together.
1)Stock baseline run 329whp/337wtq
2)Headers, SS-HT Cam, SLP Catted Headers 409whp/386wtq
3)Heads and FAST 92 intake 452whp/434wtq
"This is with Ed's SSHT (228/232) cam and ET 215 CC heads with an unported FAST 92 intake , the choker is that it has SLP headers with cats but it is a well matched street combo , the below graph shows when we dynoed it stock (with borla exhaust) and then added the SSHT cam with full bolt ons , then when we added the ET 215 cc heads with the FAST 92 intake."
Old Jun 23, 2009 | 09:37 AM
studderin's Avatar
Any of his cams are really good. They make great tq. I hand ported a set of 241s kept the stock valve job and valves, really buget. And out them on car car for a little while and it mad 466whp/410wtq, and I have a s60, gears heavy DR and clutch. With my stock heads its still 415-420whp with good tq and traps low 120s
Old Jun 23, 2009 | 10:42 AM
AznMuscle's Avatar
Yea, my cam is just with the stock 243s, and Mike (guy who actually came up with the grinds) is telling me that at our track I should be around 118 traps or so. The same cam in a z28 with a Lid, LTs, and stock 241s w/ ls6 intake trapped 115. No gears, no real weight reduction (back seats only, for his dogs). Track is 3075 ft above sea level, let alone other factors.
Old Jun 23, 2009 | 10:55 AM
jp74's Avatar
I have have the HT. Good power throughout the powerband. By buddy has the larger streetsweeper and is trapping 117.5 in good air through an A4.
Studderlin's car is badass!!!
Old Jun 23, 2009 | 11:29 AM
99blancoSS's Avatar
The ET heads are what makes that combo
I like the AFR's milled to 11:1 with the 228/232 for a great street/strip combo
Old Jun 23, 2009 | 12:19 PM
Don Nguyen's Avatar
What's the highest compression you can typically run on a stock bottom end, using 91 octane? I figure the people who I will be purchasing these parts will know all of this, but it's also nice to just cross reference things, to just know for myself personally.
Old Jun 23, 2009 | 01:03 PM
PREDATOR-Z's Avatar
It is not as much the SCR but DCR that is a factor along with cam specs (cylinder pressures).
Old Jun 24, 2009 | 11:44 PM
kenp's Avatar
That's exactly what I'm putting together.
Old Jun 25, 2009 | 02:28 AM
Paint_It_Black's Avatar
Who is Mike? I just know I've seen these exact cams on flowtechinductions.com for years, and Ed Curtis runs that shop. Did Mike work there or something?
