Camaro LS1 Corvette LS1
-exact same heads
-exact same block
-exact same crank/rods/pistons
-exact same intake manifold
-slightly different cam specs (negligible)
-different shaped oil pan
-different serpentine belt pulley layout
Corvette LS1 vs LS6:
-different head castings (LS6 flow slightly better stock)
-different intake manifolds prior to 2001 Corvettes. All 2001 and newer Corvettes and F-body LS1s have the LS6 intake.
-different cam specs (02-03 LS6 cam is much better than 01 or regular C5)
-different PCV system
-slightly different block internals (crankcase port windows larger on LS6)
-same crank and rods, I believe pistons are a bit different
Basically the pulley layout and the oil pan shape. Corvettes have a flat oil pan with "wings" on the side, which don't really fit in any other vehicles very well.
There are quite a few bolt-on LS1s running mid-high 11s with no internal engine modifications, all in the 3100-3200 lb range."
Hope it helps all this info was found in " f-body ls1 vs. corvette ls1 vs. ls6" July 17th 2003.
what's the difference between the 98 Camaro LS1 engine and the 98 Corvette LS1 engine. It's funny how GM (and car enthusiasts alike) had made all this hoopla about the 98 Camaro Z28 and SS having for the first time the same V8 engine as the Corvette. Now, yes, the numbers might have been fugged to make the Corvette more appealing to big spenders...but really, is it really worth saying the the Camaro really doesn't have the Corvette engine, just because the pulleys are a little different? Or that the might have a different intake manifold (which cane be corrected with swapping out the Camaro's LS1 manifold for an LS6 manifold)? Really...
On another note, I test drove a 2000 ws6 prior to buying my vette and I liked how strong it felt, but hated the "flex" under heavy acceleration. The car felt cheap in that respect, but I love the way it looks.
Add into the equation the solid rear axle of the f-body.....and you have almost a dead heat in a drag race. The driver is the deciding factor.....cuz these cars (despite what corvette owners say) are virtually the same in straigt line performance to 100 mph.
