cam @ 130,000 plus miles???
Old Jul 8, 2009 | 06:42 PM
BorlaTA's Avatar
Default cam @ 130,000 plus miles???
Hey guys i got a 2000 trans am with 130,000 plus miles and have all of the basic bolt ons so natually i want a little more with out building the motor and spending a lot. its a a4 and i want to use the stock stall for daily driving. So how big of a cam can i go with a stock stall. And when i do this cam im going to do the cam package with the new springs and rods also a timing Chane with a oil pump. Do you think that the motor will hold or go bang?
Thanks,
Ray
Old Jul 8, 2009 | 07:00 PM
mchdg86's Avatar
A 224 cam is about as big as I would go on a stock converter. But you will more than likely gain more from a higher stall converter. You can get a 3600 and still be very street friendly. If the motor has been maintained properly there is no reason to worry about putting a cam in it.
Old Jul 9, 2009 | 12:01 AM
Damian's Avatar
LSX Mechanic
As for the mileage, I wouldn't be concerned. I do 150K+ cam installs quite often.
On a stock converter, I've used a 224/228 XE-R 114 with great results. With a decent tune it drives just fine on a stock converter, and makes a tad more power than the standard 224/224.
Old Jul 9, 2009 | 08:09 PM
5_02ls1's Avatar
a friend of mine has a 99 z with 175,000 miles...its h/c/92/92 and makes 450rwhp...my car had 156k and was making 480 cam only with a little spray.....these engines are like no other when it comes to long life....
Old Jul 9, 2009 | 08:20 PM
AGRV8TD's Avatar
160,000 on my car when we tore it down had the heads mildly worked and added a G5X3.
I made 405RWHP on a loaded dyno with a 4000 converter cam only.
These cars when maintsined properly last a long, long time
Old Jul 9, 2009 | 08:21 PM
AGRV8TD's Avatar
224/228 cam is exc3ellant for overall drivability and power on a mild or stock converter
Old Jul 10, 2009 | 10:37 AM
85Iroc's Avatar
Luckily for me I got one that someone had screwed up the PCV system on so now its apart getting freshened.... damn worst sludge I've ever seen.
Old Jul 10, 2009 | 07:31 PM
BorlaTA's Avatar
I am thinking about doing to do a slight stall but am unsure on the size yet. I am thinking about a 2000 stall. If i get a 2000 stall what size cam could i use for daily driving?
Thank you guys!
Old Jul 10, 2009 | 07:54 PM
Johns00Z28's Avatar
3600-4000 stall! You'll love it.
Old Jul 10, 2009 | 08:34 PM
slt200mph's Avatar
I am on my third cam on this motor it went in at 128,000 miles and the motor just turned over 190,000 miles this week....452/418 at the wheels and still going strong ...
Old Jul 10, 2009 | 11:09 PM
BorlaTA's Avatar
What size stall and cam do you have in your car?
Old Jul 11, 2009 | 06:50 AM
slt200mph's Avatar
It is a custom cam from Comp the car is a six speed
Old Jul 11, 2009 | 09:49 AM
BorlaTA's Avatar
OK made up my mind I'm going with a 3200 yank stall but am unsure of the cam still. What size cam are you ls1 members running on a 3200 stall. Or what size cam should i run.
Thanks guy i really appropriate the info.
Old Jul 11, 2009 | 09:51 AM
Damian's Avatar
LSX Mechanic
With a 3200 you'll want something that makes good midrange power to compliment the converter. The 224/228 that was recommended above is still a great cam for that setup. I've actually swapped out that cam for a bigger grind on a 3000 stalled car, and it lost power and went slower in the 1/8 mile.
I wouldn't do ANYTHING bigger than 230 degrees of duration in an automatic that's daily driven, and keep it on a 113-114 LSA for better driveability and ease to tune. Been there, and done it lots of times.
Old Jul 11, 2009 | 10:20 AM
BorlaTA's Avatar
So would you recommend the 224/228 cam on 113 or 114 lsa to make good power.
Old Jul 11, 2009 | 10:22 AM
BorlaTA's Avatar
Or a 228/228 duration.
Old Jul 11, 2009 | 05:20 PM
stumprrp's Avatar
i have a 3600 and use a 230/236 cam on a 114 LSA, its very easy to drive, but for max effort drag racing i think a 4-4200 would be better.
anyways something in the high 220's low 230's would be nice.
Old Jul 11, 2009 | 08:26 PM
mknight759's Avatar
looks like alot of miles to me but i guess its hoe its all been taken care of
Old Jul 11, 2009 | 09:48 PM
99Ls1fever's Avatar
Very Interesting thread, I have always woundered this personally. Good Info Guys!!!
Old Jul 15, 2009 | 09:53 PM
BorlaTA's Avatar
1 more question. would anybody worry about spinning a cam bearing with 130000 miles???
