Cam Guru's, help spec me a 383 cam!
Old 07-25-2009, 02:04 PM
a98ws6's Avatar
Default Cam Guru's, help spec me a 383 cam!
Getting ready to drop my 383 in my car but would like to install the cam before.
The motor is as fallows:
383ci
4340 crank
Lunati Pistons
Crower rods
LPE cnc'd ls6 heads (was told 11:2:1 compression installed)
New stock lifters and rockers
Moly pushrods
No valve springs yet but it will be whatever dual springs will handle the cam
New ls6 intake and ported TB
Meziere race EWP
No headers yet but will be TSP 1 7/8 or LPP stainless 1 3/4
Car has a TH-400 with a Yank 3800 converter and Moser 9" with 4.11 gears. Lots of !weight mods and will just be driven to and from the track. No daily driving here.
If I need to change parts from this combo, id rather do it now while the motor is out.
I had a TREX before and want something a bit bigger. Also plan to spray sometime later with a 150-200 shot.
I know the ls6 intake is going to hurt me but for now it will have to do.
Old 07-25-2009, 02:18 PM
a98ws6's Avatar
Also would like your opinion on these 2 cams.
248/248. .615/.615 111
247/251. .623/.623. 113+3
Old 07-25-2009, 03:27 PM
quick346's Avatar
I would pay patric g the 25 bucks and let him spec it. he will calculate the dcr and give you the best combo.
I have went with him twice and feel he is worth the money. I am very happy with my lsl lobed 243/251 624/624 on a 110 for my 346.
Old 07-25-2009, 03:40 PM
GreenBlood's Avatar
pm predator-z
Old 07-29-2009, 07:22 PM
a98ws6's Avatar
I was just hoping somebody could tell me if the cams I posted are in the right direction for what I want to do and my supporting mods?
Old 07-29-2009, 07:24 PM
SMOKNSS's Avatar
Just give Patrick G or Geoff@EPS a shout. Money WELL spent.... those guys know whats up.
Old 07-29-2009, 09:28 PM
Lazpno's Avatar
How high do you plan on spinning the motor?
Old 07-29-2009, 09:34 PM
a98ws6's Avatar
6500-7000 whatever it likes.
Old 07-29-2009, 11:31 PM
Lazpno's Avatar
I personally would go for the 248/248 cam out of those two. I'd use a different LSA though if you plan on spraying it often to bring down the overlap.
Edit: The 247/251 sounds like a newer LSL lobe cam and may be of more interest to you though considering the more aggressive ramp rates than the 248/248 xfi.
Old 08-02-2009, 02:41 PM
JPH
JPH's Avatar
Use the 247/257 113+3 cam for "KILL MODE".
Old 08-02-2009, 03:42 PM
PREDATOR-Z's Avatar
Cams mentionned too big for stall you have. I prefer something like this:
240/244 .609/.614 110+2 LSA
Old 08-02-2009, 06:31 PM
a98ws6's Avatar
Would a 4500 stall be better for those bigger cams? How would the cam you suggested run on the N2O? What lobes?
Old 08-03-2009, 05:47 AM
PREDATOR-Z's Avatar
Well it depends on brand, str, efficiency etc.... That part i'll leave to the TC masters.
Basicaly one has to look at shift extentions as well, like matching stall speed 300 rpm before trq peak for best ETs. (something like that)
even that 240/244 is on the edge of big for that stall.
All in all, match your combo (LS6 intake and stall are your limiting factors here and you'll benefit more by a smaller cam that fits right in the range of both of these.)
Lobes are Comp Cam XE-R and is nitrous friendly at the powershots you mentionned.
Old 08-03-2009, 07:17 AM
9secondsflat's Avatar
i would go with the vindicator cam from vengeance...its a bit more duration and lift then the vrx5.
Old 08-03-2009, 10:31 AM
PREDATOR-Z's Avatar
Vindicator- 240*-244*-.608”-.596” - 112* LSA 108* ICL
Difference this is XE-R/XE lobes and mine is pure XE-R
Old 08-09-2009, 03:14 PM
a98ws6's Avatar
I have a chance to get a FAST 90 at a great price, and I was wondering how much of a difference would the 90 make with these bigger cams over the ls6?
Old 08-09-2009, 04:48 PM
PREDATOR-Z's Avatar
It depend on the overall combo, it can range from 10>20+rwhp
Old 08-09-2009, 06:10 PM
MelScrilla's Avatar
i say grab the fast if it's a good deal, spinning the motor high is going to want the extra air.
Old 08-10-2009, 10:18 PM
BAD2000TA's Avatar
What is everyone's opinion of the MS3 cam for a 383?? I'm thinking of going bigger for my set-up.
