Cam's with same specs but diff manufacture?
I use Comp (my designs, not their off-shelf stuff), and Cam Motion. Neither have ever let me down.
the xer 287 from comp or jegs is a ms3 or a c cam from hpe
they are all xer comp lobes (the cams i listed) just with fancy names because a xer281 dosnt really sound that cool)
just need to look at the lsa on them
all the direct from comps are a 112+2 combo. sometime's the new named lobes may have a slight change in the advertising but the cam cards are prob identical
they are good cams just do some homework before you chose one
but on a side note the ms3 has the xer lobe's and comps master list only list a 238 not a 237 lobe hhhmmmmm maybe it cam docters at like 237.5 who knows
no matter what the name if the vender uses comp to grind it you can find the lobes in the master lobe list.
