Yet another Cam question
My aim for the build is something that will make good power on the street throughout all RPMs HOPEFULLY and maybe once every blue moon take to the track. Not a DD only driven about 10 days a month. Im gonna go with GMMG full exhaust....and Im trying to decide between the MS4, The T-Rex, and the Polluter.I want something that is loud and sounds good but NOT OBNOXIOUSLY loud. Im leaning towards Heads and Headers next but I gotta find a GOOD/GREAT cam 1st. Ive been living on this website for a while now but I still cant make up my mind.....someone PLEASE HELP.....an suggestions and why?
Thanks for the help in advance guys!!!!
Exhaust is done before a cam.
Biggest is not always best/fastest/quickest.. View my revious started threads at "Lemons12 VS Lt1 z28".. My baby 226 cam to his ms4 cam..
The stock cam made a LOT more torque down low until about 4k rpms and then they were even until 4200rpms and the MS3 took off...
I think I'm going with a 228/232 cam...
Do the Exh. first then go with a TR224 or a 224/228
Many people start with the Big cams then they usually go for something smaller for street use. Try it ?
Big cams require supporting mods to perform. What you would need with the ones you mentionned:
1- LS6 intake (minimum)
2- Better clutch
3- Higher gear ratio (4.10+)
4- Headers, ory, catback or duals
Those are the minimum necessary mods. Now how are you going to be driving on a regular basis? 90% street? then those cams are too big.
You want lope? then you need overlap. Sweet spot for overlap on street is 8>9* overlap
How far do you want to shift? 6500 or less? Those cams are too big.
Most important is, how big is your budget? determine that and work out a plan accordingly.
Anyway you look at it you need at least $3000 to have a decent power producing combo.
Exhaust-intake-cam-Tune (assuming you do all the install yourself.)
2- Better clutch
if youre bone stock, you have a lot of stuff to do before you even think about a cam.
Lid, ls6 intake (FAST if you can afford it), headers, the rest of the exhaust (Y pipe to a catback or true duals). and you need mroe than just a cam. you need springs, oil pumps, pushrods, and theres alot more stuff that would be a good idea to add. also, you might wanna start preepping for the cam (i.e. injectors, clutch, fuel pump etc.) and youll need a tune no matter what.
you power curve would suck with anyone of the cams you suggested. you want to be able to drive it aroundwith power all over the band, well you need something smaller than those. high 220's/mid 230's will suite your driving habits/wants pretty well. go spend a very long time looking through as many dyno sheets in the "Dyno results and comparisons" forum here, just a few down. look at as many different types of cams as you can until your head explodes. that will give you a foundation on where the power will be. look at differences between something like a 224 cam, 228, low 230s and then a big **** like an MS4, trex, polluter, vindicator, etc. all their power is up top. do your homework first, buy all the supporting mods you will need and then come back to getting a cam. you can never spend too much time researching...
"see sig"
edit: okay, now that should get even more questions answered lol
