Building Road Race LS6
Fast 90mm & LS2 TB both ported
Bosch 40lb fuel injectors
TFS 215cc heads milled to 60cc
Cometics 0.040 mls head gasket
Patriot Extreme Valve Springs, shimmed
Comp Cams custom grind 236/243 112lsa +4 degrees advanced
597/610 lift @ 0.50 (around there, waiting on cam and specs card)
JE forged domed pistons, 6+/-cc's (waiting on all measurements)
JE forged lightweight I beam connecting rod
stock micro polished crank
cleaned and bored LS6 block, still 346ci
Good luck with road race answers on here. I go from the road race forums to Gen 3 internal with the same Q's. Not many people on here interested in the bends it seems like. You'll get lots of views and few answers. Drag is HUGELY more popular. Maybe cause you see over 280* oil temps with out a cooler RR'ing and the motor starves for oil in a long bend if you don't prep for it.
Your trick flows will make you happy i'm sure.
I hopeYou'll hate mid corner shifts upsetting the F/R balance. Unintentional understeer/oversteer will kill the road racing experience (not to mention lap times and safety). Get a M6 FO SHO
If you plan to road race dump that automatic 100% or there is no need to go as big. If you only want to AutoX then it should be fine
..... but AutoX is about 1 minute long and road racing is generally 20 minute sessions..... Spend $150 on a used oil cooler or a little more for new and it will help you big time on the street. Street cars can typically see 260*+ oil temps=lower oil pressure. Get the biggest cooler you can fit and you'll see better oil pressure. Sometimes 10+ psi in the entire rev range. Great insurance. Especially if you're on a budget...
Thnx Darkman, I'll look up Canton, sounds good.
You will need a trans cooler as big as the engine radiator to keep the trans from burning up. They just won't take the heat. Good luck, you are going to fight a long tough battle on that one. It would be waaaaaay easier to get a 6 sp.
