Piston to cylinder wall clearance- what can I get away with?
Since I have just about given up on finding a stock LS1 block at a reasonable price, I am contemplating just rebuilding the old block even though it has been honed before. What is the max piston to cylinder wall clearance I can get away with when rebuilding this engine? It is just a little more gap than I was hoping for, but I am thinking with a quick hone it wont be too bad. This will be for a daily driver with no power adders or after market parts, and will be used for a daily driver, about 500 miles /month. I will be using all stock internals, and the engine is out of a `98 Trans Am.
Thanks.
Thanks.
Ok guys......so I am considering the coating option now, since $150-$200 isn`t too bad. Does anyone have experience with this? Am I looking at long turn around times? Is this something that I can have done locally, or is it something only a very few specific companies can do?
Thanks.
Thanks.
Oh, also I ceramic coated my piston tops, thermal dispersant coated the bottom and moly coated the sides. But, don't count on any of that. When metal expands, it expands.
Edit. Oh ok. That is for 2618 alloy. If you are using 4032 Alloy, then take 15% off my figures.
