If someone dropped your motor, would you be worried?
Hi Guys,
Just a question. If someone had dropped your freshly built motor whilst loading it onto the back of a low pickup because a chain broke...maybe falling 3-4 feet, would there be a likelyhood of internal damage?
Originally Posted by CANNIBAL
Hmm, it can't be a good thing. It could have done damage. Are there any visible cracks, etc?
More concerned about the possibility of internal damage caused by the shock of a drop ...balance problems etc. Hoping there is no damage.
Any 'Spanners' here able to help understand the possible consequences?
As long as didnt land on either end of the crank you should be alright, if it curshed you pan though I would be checking for damage. also check to make sure no head bolts were pulled out, and obviously that here are no cracks were the impact occered.
I'd definitely check and replace the oil pan gasket. It's most definitely damaged and crushed, and you don't want a leak after you get it installed, or have engine damage because some of the damaged gasket material became lodged in the sump screen. I'd check and closely inspect the oil pan, and the oil pump and the sump. I would debur any scratches and nicks also. If you're superstitious, this is not a good omen.
The oil pan is a structrual part of the block and the alignment of it is critical. I would worry about damage to the pan and would drop it for sure. Be forwarned that GM recomends a special tool for aligning the rear parts up after dropping the pan. Also you will find that the gasket (rubber o ring style) is held in place by 2 rivets. They are for convenience only and can be drilled out permantantly.
Here is a quote from the tech manual from a 99 fbody.
"Important: The allignment of the structural oil pan is critical. The rear bolt hole locations of the oil pan provide mounting points for the transmission bellhousing. To ensure rigidity of the powertrain and correct transmission alignment, it is important that the rear of the block and the rear of the oil pan are flush or even. The rear of the oil pan must NEVER protrude beyond the engine block and transmission bellhousing."
Make whoever dropped responseable for taking it apart and have it checked.
Oh what fun it would be to pull back out and fix it later if something is wrong.
I would be concerned. The block is the foundation of a good motor, and could cause you to lose the whole engine if there is cracks or coolant leaks. It's hard to say what I would do, but I would be ready to go postal seeing my engine dropped.
