is it possible to put lifter back in without taking off heads?
craftsman makes one with a light at the end of it....
then you would have to get it in the hole from far away with no control as to its angle or position of the lifter.....very unlikely
heads are coming off
it's not too bad, just more expensive. On the upside, while they're off, you can send them to Total Engine Airflow and get them ported-
that would net you a huge amount of gain at once.
where did the lifter fall to?? I mean can you get it out some how?
where did the lifter fall to?? I mean do you get it out some how?
my motors torn down to the short block so look at these.
heres a pic of the rear hole under the valley cover
and heres a pic with the head off showing that you could maybe get a lifter started back up into #8, threw the hole under the valley cover.
Now i know its a long shot but u gotta take the intake off anyway if ur going to have to pull the heads, right??? So id pull the valley cover off quick and then make ur own decision. Good luck getting that pan off and finding that lifter. Hope this helps.....
So how do you get inside the engine to change cam bearings or pull lifters out?
It almost seems like you have to turn it on it's side and shake it.
To change the cam bearings im pretty sure ud have to tear the whole motor apart ''bottom end''
To pull the lifters out u have to pull the heads and then the lifter trays.
Luckly when i did mine i left the cam in when i pulled the lifter trays and lifters. If not a couple of mine would have fell into the oil pan as well.
