loud ticking noise
Old Nov 11, 2009 | 04:35 PM
Big Black SS's Avatar
Default loud ticking noise
yesterday i was at the store ,got back in the SS and i noticed a ticking sound, looked at the oil pressure gauge and it was almost to zero ,turned the car off checked the oil and it was a lil low(half quart) i filled it up to where its suppose to be, but no luck ,drove it home oil pressure was up a lil while driving it. now if i turn it on the pressure gauge is at zero so i turned it off as soon as i sawe that .....what is it oil pump?
Old Nov 11, 2009 | 07:15 PM
TURBO6.0L's Avatar
Sending unit could have went bad. Is the engine making any funny noise? Try to get a mechanical oil pressure gauge on the car to be sure.
Old Nov 11, 2009 | 07:32 PM
hokie00 TA's Avatar
it sounds like the pump has gone bad i had a friend with the same problem a few weeks ago same symptoms he changed the sending unit and same problem, he changed the pump and that fixed the problem
Old Nov 11, 2009 | 09:40 PM
SOMbitch's Avatar
It is ticking dude.....
Could be one of a dozen things but OP failueres were were common on the 98-00's.....
Old Nov 11, 2009 | 10:53 PM
G Engines's Avatar
The ticking sound is most likely your lifters due to the low oil pressure. Hope you haven't hurt any thing else in your engine from driving it.
Old Nov 11, 2009 | 11:16 PM
elias_799's Avatar
how far did you drive it ?
you should of never driven it if you where not getting oil pressure. next time call a tow truck. it will be cheaper.
Old Nov 11, 2009 | 11:52 PM
DarkJuggalo's Avatar
ouch.... i made that mistake once on an older car. messed up the bearings and had to buy a new cam. will never drive a car home with 0 oil pressure even if its only a mile
Old Nov 12, 2009 | 05:36 PM
i drove it like 5 miles but the oil pressure was at like, at the first white line...oh yeah its ticking
Old Nov 12, 2009 | 06:24 PM
TURBO6.0L's Avatar
Since you are only hearing the ticking and no knocking or squealing hopefully no bad damage. Good luck.
Old Nov 12, 2009 | 08:20 PM
i hope so,,,i just spent $3200 on transmission 6 monthes ago...
Old Nov 12, 2009 | 08:26 PM
ae13291's Avatar
what year is the car? i just had my oil pump go bad, i inspected the oil pump and it was a sticky relief valve
Old Nov 12, 2009 | 08:28 PM
its a 99 SS
Old Nov 12, 2009 | 11:15 PM
ae13291's Avatar
^^^ my car is also a 99. im at 92k miles right now and my oil pump crapped on me. i cought it as soon as i started it in the morning, but i never drove it like that. 97-2000 LS1 motors had the problem with the oil pumps, they made a better oil pump in 2001
Old Nov 12, 2009 | 11:39 PM
elias_799's Avatar
get a melling 296. i get 70psi at cold idle
Old Nov 13, 2009 | 12:32 AM
nightmare23's Avatar
could also be a spun bearing .. drain ur oil stick a magnet to check for shavings ..if not any change out the oil pump and lifters as well while ur at it
Old Nov 13, 2009 | 10:01 AM
elias_799's Avatar
^lifters is a bog job. it should be done in a situation like this, but i just hope op knows that you need to pull the heads to do that. i would change the oil pump and see if it is still making the sound. but first of all check the oil pan. you might need a new motor
Old Nov 14, 2009 | 08:46 AM
350 WS6's Avatar
dude i have the same problem. you have weak lifters and cam and rocker arms. everytime i drive mine the oil pressure gauge is fine and then not 5 miles later it is at zero. and you might wanna check the oil pump cuz its not circulating barely any oil.
Old Nov 14, 2009 | 03:54 PM
elias_799's Avatar
he does not have weak rocker arms. the problem is that the oil pump is not filling up the hydrolic lifters. or maybe he spun a couple of bearings and is not getting any oil pressure. it is really hard to tell unless he post an audio of the sound the motor is making. but if he drove the car wiht no oil pressure there is a very big possibility of him making some damage.
Old Nov 14, 2009 | 07:00 PM
ima drain the oil tomorrow and see if there is shavings in it , i hope not.if i would of spun a bearing ,wouldnt i hear squeeking??i kinda dont want to make a video because i dont want to star the car ...
Old Nov 14, 2009 | 07:11 PM
elias_799's Avatar
if you spun a rod bearing you will hear a loud tick. and the pase of the tick will increase as you up the engine rpm. it is kind of hard to explain the noise difference between faulty valvetrain and bottom end in words. i am sure if you type it in utube you will find some good examples
drain the oil and post up some pictures, so we can help you out.
