Hole In Piston symptoms
It smoked like a bug fogger. tore it down and it had about a 1/2 inch dia hole blew through it. I just threw another piston and rod in it that i had from the last moter. reused the bearing and she was back together.
I have like 6 pistons and rod asy with arp bolts left if you need one let me know you can have one.
What you need to do is a compression test as soon as you can, this will help determin the problem, if you have just 1 cylinder with no pressure then you narrowed it down, if you have multiple then you may be looking at a head gasket. could be burnt rings to.
I am new here, what mod is there for #7 I plan to run nos so this tip would help me out alot, I have heard alot about that pistion being the weak link
