TEA ported stock heads?
i was thinking of pulling the stock heads and sending them off to some place like TEA or other michine shop to port my heads. has anyone else done this?
TEA or Advance Induction. I sent AI my 243s with valves, springs retainers etc...they charged me $1085 to do all the CNC work and assemble them. Now like stated before me 241s are not worth the time, I know from experience and 1500 dollar investment into heads that I changed out for 243s.
There is no point in spending money on 241/853 casting heads. You'll be down a grand for very little performance gains. Find a set of 243's and have TEA do them (I have their Stage II LS6 heads on my car, and had them supply the core), or go with Trick Flows.
LSX Mechanic
241's are fine, and will make power but not as much as a 5.3L or LS6 head. The biggest reason 241's suck IMO is due to the cc size, and the fact that you drastically reduce PTV clearance if you try to get any compression out of them by milling.
You're better off minimizing downtime by buying something outright, such as a fully ported casting ready to be shipping rather than shipping yours out and waiting 3-5 weeks for them to be finished.
I have their stage 3 5.3 heads and they freakin rock. I later called about changing my setup and going to trick flow heads. They told me not to spend the money because I wouldn't see hardly any difference in power between the heads and the only reason for me to get the TF is for the thicker deck surface for a better clamping potential of FI or big hits of nitrous.
I made 460whp with some 241s I ported
https://ls1tech.com/forums/generatio...ted-heads.html
really????
