ported ls6's vs ported trickflows
Old Dec 15, 2009 | 07:54 PM
ls1curt's Avatar
Default ported ls6's vs ported trickflows
hey, i was wondering what is the difference between a set of good ported ls6 heads and a set or ported trickflows or afr's. the trickflows/afr's are a lot more expensive, but if you are getting them both ported, what are the difference's?
Old Dec 15, 2009 | 08:25 PM
01FbTaWs6's Avatar
flow numbers, chamber design, runner design. They are all together different castings. The TFS, AFR's, ET's are all just a better head all around. That being said ported LS6 heads are a far cry better then stock 853 or 241 castings. If your looking for a set of heads, ive got a set of cnc ported stage II's for sale. Just PM me if your looking.
Old Dec 15, 2009 | 11:04 PM
fatmat80's Avatar
My opinion:
TFS
Ported LS6
AFR
I have seen all three in action and thats the order dyno numbers came in as well as the races..just my two cents.
Old Dec 15, 2009 | 11:26 PM
02*C5's Avatar
The LS6 is a great set up for a budget build, and worked on by either AI or TEA they will flow close to AFRs. TFS are a monster all of their own. They can make any build perform extraordinary.
Old Dec 16, 2009 | 06:13 PM
ls1curt's Avatar
okay thanks for the info. i prob wont be doing heads for a lil while, gotta see how she is with the new cam first but ill prob just end up doing a set of prc ls6's. or how do even stock ls6 heads flow over 241's
Old Dec 16, 2009 | 06:34 PM
transamfreak01's Avatar
the ls6 243 heads will perform better. i would just buy a used set of 243s for a couple hundred and do the h/c at the same time
Old Dec 16, 2009 | 08:11 PM
ls1curt's Avatar
i know i should but im a little tight on money right now. gotta have something to look forward too
Old Dec 16, 2009 | 08:43 PM
NemeSS's Avatar
tfs will always have higher resale value compared to ported stockers.
i would never pass up a set of tfs over ported stockers if was within budget
Old Dec 16, 2009 | 08:57 PM
SOMbitch's Avatar
TFS are GREAT just realize you have to run aftermarket rockers with them that are in the $400 range or more..... I wouldn't hesitate to run AFR either. The T4P Joe Mendelis 243's will run with these heads too. Only saw one set on a car but WOW best 243's out there....
Has Cary (old ETP heads) come out with his new heads????? I am sure they will kick ***!!!
Old Dec 17, 2009 | 06:52 PM
chrs1313's Avatar
thunder has been running stock rockers on TFS for 2 to 3 years now without a problem
and all aftermarket heads really need to use roller rockers with the bronze guides...
