Cam "Wish list" - Need your input
Here's my cam "wish list" for you to ponder and offer a recommendation
when you get a chance:
1. Good flat torque curve
2. Good low end power
3. Good power increase overall
4. Very slight to barely noticeable lope
5. Good idle and starting qualities
6. Emissions freindly
7. Good driveability, no surge.
8. Low valve train noise
9. Good solid setup, low/no maintenance issues.
So that's not asking too much is it?
Thanks for your feedback.
A good tune will get you what you are looking for. That is the key to being a daily driver and the valve train noise is not bad at all. With comp 918's springs
But I have to say the ones That JP listed are where you should start to read about each one, its pros and cons then GET one of them.
Good luck with your wish list.
Pete
The comp 216/220 is an oldie but a goodie and it fits your wish list perfectly.
Not meant to be a flame, but I wouldn't go through the trouble of a cam install for anything smaller than a 224.
Wes
Wes
It covers everything you asked for except the emissions part. I've had this cam in for about 20K now with no real issues.Crowley
With that low/no maintance on the list and the other stuff, I think an LS6 cam might be worth considering to some degree if you really just want to install and forget about it.
The TR-220 & TR-224 are excellent cams for your application IF your willing to change valve springs occassionally.
If you going to do heads with in the next year or so - I'd go with a 224 XE-R or something similar on a 113 or 114. You can get a year or so out of the springs that go in with the cam and when you do heads get duals or 921's or something etc and have fresh springs that should last for another year if you beat the car hard and maybe two or three if depending on how you drive.
The LPE GT2-3 on a 118.5 LSA will give you all the stuff your looking for and drive stock...this cam has been accused of having a Better Idle that stock but it will need springs on occassion too. It's a 208/220 .573/.580 118.5 LSA ie sort of a BIG LS6 cam with more lift and duration IMO. However, a good 224 ish TR/XE-R cam will be able to make more power all things being equal.
was doing my research on the c1 and i saw that you had it before the tsp 231. im swapping out my 230 for the c1. yes, yes, i know, going smaller WTF. but its more inline with my new goals.
