Zero Oil Pressure
Zero Oil Pressure
Today my oil pressure dropped to zero in my 98 Ls1. I'm pretty sure I need a new oil pump, my question is what should I get? I read on here that a high volume unit can suck the pan dry at higher rpms. Is this true? I found a brand new Ls6 oil pump, will this work? Thanks in advance for the help
http://www.texas-speed.com/shop/item...d=215&catid=55
This is the Ls6 pump, anybody deal with these guys?
Thanks for the quick responses. I have an aftermarket gauge that uses an oil tube so I know the oil pressure dropped. People have been saying I'm going to need new main and rod bearings. Is this really necessary? How about a Melling unit? Something like this
http://www.summitracing.com/parts/MEL-10295/
1 Post
1 Post
Yea we didn't. Before it dropped to zero it fell to about 7 and started running poorly. 7 psi of oil pressure is low but its enough to prevent damage. Once it reached zero we immediately cut it. It ran at zero for less then 2-3 seconds which doesn't seem like enough time to do any damage. Hopefully we're right
i have the melling 10296. if you plan on doin any modding like a cam or heads i would go with the melling or ported ls6 from Texas. And you would have to be pretty low on oil to suck the pan dry, someone correct if im wrong but im almost positive the LS1/Ls6 can only consume about 3 quarts before it cycled back through the filter and pan. So your only sucking it dry if your down 2-2.5 quarts.
