LS2 timing chain on LS1
Old Jan 25, 2010 | 10:49 PM
Bjorne043's Avatar
Default LS2 timing chain on LS1
While doing my H/C package I'm going to put on an LS2 timing set up. Does this just bolt on or do I have to change out my balancer or anything to make the chain fit?
Old Jan 25, 2010 | 11:08 PM
racerx17x's Avatar
just bolts on.
Old Jan 25, 2010 | 11:19 PM
01ssreda4's Avatar
direct fit....
Old Jan 25, 2010 | 11:30 PM
SOMbitch's Avatar
Don't even have to change the gear if it is is good shape which I have never seen bad yet.....
Old Jan 25, 2010 | 11:31 PM
hcb1700's Avatar
Bolts on.
Old Jan 26, 2010 | 09:57 AM
D.Jones's Avatar
dont mean to , but I am also going to do the same thing and wanted to know where would i go to get a ls2 timing set beside the stealerships?
Old Jan 26, 2010 | 10:09 AM
01ssreda4's Avatar
The sponser Yank sells them, as well as SDPC and TSP, Thunder Racing.
Old Jan 26, 2010 | 10:15 AM
slt200mph's Avatar
I paid $27.00 for a LS2 chain at a Chevy dealership. I beleive that the LS2 chain has superseded the LS1 chain. It is much heavier duty when compared to the old LS1 chain.
Old Jan 26, 2010 | 08:09 PM
Red99TA's Avatar
Yank was also selling adjustable single roller LS2 timing sets last summer - not sure if they still are.
Old Jan 28, 2010 | 09:57 PM
printmanjackson's Avatar
question on these chains.... just how long are they good for? Over at the Corvette forum here is a LS2 chain with 16-18K miles and look at the slack!
http://forums.corvetteforum.com/c5-t...-begins-4.html
makes me wonder why this one did not hold up better.
Old Jan 29, 2010 | 05:59 AM
Red99TA's Avatar
That amount of slack doesn't look out of the ordinary to me. These chains have a little slack in them even when brand new.
Old Jan 29, 2010 | 09:31 AM
slt200mph's Avatar
GM designs their engines with a 200,000+ mile life span. When you consider how many of these LS series engines are out there in service with tons of miles on them it is obviously a durable part ... F body cars and Corvettes are just the tip of the iceberg ... think about how many trucks and SUVs are using these engines ... I see Silverados in our service department all the time with over 200,000 miles on them...they may be on their second or third transmission but the engines are still performing great. I have put 60,000 one LS2 chain and then did another head and cam change and have 77,000 miles on the one in the car now. It is a quality part with great durability.
Old Jan 29, 2010 | 09:58 AM
ok so that much slack is considered normal. Will this not retard the cam and valve timing enough to change engine performance?
Old Jan 29, 2010 | 10:13 AM
LS1-450's Avatar
Maybe. As mentioned, the slack doesn't look too bad. The question is, how much space did it have to begin with & was the cam degreed w/ the chain in tension?
Old Feb 2, 2010 | 01:08 PM
I wonder if this much chain slack can cause it to break.
Old Feb 3, 2010 | 01:14 AM
Bjorne043's Avatar
would you guys recommend the whole set up or just the chain?
Old Feb 3, 2010 | 04:41 AM
LSxPwrDZ's Avatar
Depends on how the cam gears look. I did a cam swap on my 98 and it had 100K miles on it and the gear's looked fine so I just tossed a LS2 chain on it and rocked it. It will take a special puller to get the gear off the crank also so be prepared for that.
Old May 3, 2010 | 01:46 AM
SApache40's Avatar
I have this issue when I installed a brand new LS2 timing set. I got the cam gear dot to line up with the crank gear dot. I torqued the bolts on the cam. Now when I move the crank shaft either way there is slack and makes the dots not line up. Is this normal or am I doing something wrong?
