Cheater V3
hp & tq yet is less choppy and is more A4 friendly that's the one i'm going with. I've had 3 LS1 f-bodies and had different kinds of head and cam setups and i found out that i made only a few more hp with the TR224 cam over my old Comp. 216/220 .525/.532 114lsa cam.
Through my A4 with a Vig.3600 i dynoed 408rwhp and 397rwtq with a set of stage 1 241 heads and the 216/220 cam. The TR224 only gave me 5-6 rwhp and that was only at peak. And the smaller cam gave me alittle more tq in the lower rpm range. And since i had an A4 the 216/220 cam was more A4 friendly, but after i bought LS1-Edit (the only software available back in '02) i was able to get bigger cams to idle nice. If i ever get a chance to mod my '02 SS A4 i'm staying with a smaller cam like the Cheatr V3 cam. Since my car will be 99% street i don't need a cam that makes it's power above 6,500 rpm.
And the new GTP heads have a small intake runner, around 208-210 cc's and flow over 300cfm, with the Cheatr V3 and a Vig.3200 with longtubes, catback, ported TB should make for a strong running street setup with tons of torque. I like the TrickFlow 215's but the GTP ported 241's for $1,200 will have to do. Good luck to the OP with your plans.
posting about is because a lot of guy think you need to run a big cam, and they try and tell you that a 230 cam idles like stock..lol. If you plan on shifting at 7,000 rpm or higher
and give up your driveability then a 228+ cam is what u want. It depends on your plans with the car. But don't let people talk you out of buying a smaller cam if that's what you want.
That kind of response gets annoying you know. I think most of the guys doing those cams probably tune the car themselves and think everyone does the same.
Now if Pat would have said something like " i can get you a cam with the power band and results your looking for. What engine do you have and what mods? "
If he would have said something like that to show he was interested in helping i would have given him the $25.
Thats just my opinion.
any LS based motor there's probably a cam that's already out there that's
close to the spec's and performance to a more expensive custom grind. But i see what u r saying.
show it's gains in higher rpms and you'll need a geared to death rear and/or a huge stall. I like the less is more approach, unless i have a gutted out track only car.
larger than mine and i won or gave them a run for their money they couldn't believe
i only ran a 216/220 cam and on a stock 3.23 rear. The one guy i remember ran a 228/228 cam with huge runner heads or something. If we were racing 1/2 mile instead 1/4 mile i'm sure he would have taken me...lol But geeze i let off once we hit 100 mph. He did go by me once i let off...lol. We pulled over and talked for a while. I was shocked when i saw he only had the driver seat in the car..lol. And i had my full weight WS6
His cam did sound good, i had my borla capped and u couldn't even hear my cam..lol. I love stealth.
slightly higher idle, even with the LM1 you can't tell the car is cammed
04 GTO
auto
K&N CAI
Headers/no cats/LM1
UD pulley
(Car made 392hp I don't know the TQ though.) Not bad at all in my opinion
Edited, did some research and found that these cams do 365-375rwhp
My friend is prob full of it
04 GTO
auto
K&N CAI
Headers/no cats/LM1
UD pulley
Car made 392hp I don't know the TQ though. Not bad at all in my opinion
