Cheater V3
Old May 5, 2010 | 05:04 PM
  #101
LS12Fast4U's Avatar
Definitely will guys. I guess im off to by heads now hahahahah
Old May 5, 2010 | 05:11 PM
  #102
ds98formula's Avatar
It will never end lol
Old May 5, 2010 | 05:57 PM
  #103
LS12Fast4U's Avatar
Actually I think I'm going to put 4.10's in it first.
Old May 5, 2010 | 08:46 PM
  #104
hammertime's Avatar
Originally Posted by LS12Fast4U
Well got the dyno numbers. Im a little dissapointed it wasnt more but with the great drivability and it didnt need much in tuning it is a nice cam. If i had a set of heads im sure it would be at 400 rwhp. I was at 361 RWHP and 351 RWTQ. Note that i only gained 1 hp peak but my torque curve stayed virtually the same from 2600 up where my HP increase was noticed from 4500 up.
The stock cam fell flat at about 5300 where the Cheater V3 was still building power to 6800. Between 5400 and 6800 i was peaking and making 30 HP more then stock.
Wait, you gained 1hp at the wheels with that cam? Same dyno that you had used previously?
If your new cam continued to pull past the stocker from 5300 to 6800, and the torque curve never fell off, then it sounds like your dyno results are skewed. I agree with the others here - don't get to hung on the number, see what the track says before you make more changes.
Old May 5, 2010 | 08:52 PM
  #105
LS12Fast4U's Avatar
No that was torque. HP jumped from 334 to 361. After 5300 RPM i gained over 40 HP.
Old May 5, 2010 | 09:03 PM
  #106
XtraCajunSS's Avatar
Those numbers are solid out of a GTO especially with the K&N CAI. I would expect to see close to 390-400 with a FAST and an AEM Brute Force intake... We just finished a 5.3L 08 Silverado Z71 CC. With the CheaTR V3 and Thorley shorties through stock cats and an unlocked PTC 3000 converter, we saw 339RWHP... The GTO's are really held back by the elbow in the intake tube.
Great results! Thanks for keeping the thread updated.
Shane
Old May 6, 2010 | 08:05 AM
  #107
hammertime's Avatar
Ok, that sounds more like it - nice work!
Old May 6, 2010 | 10:59 AM
  #108
kinglt-1's Avatar
Nice results...like shane said go with the aem intake and a fast before you do the heads!
Old May 6, 2010 | 08:57 PM
  #109
LS12Fast4U's Avatar
Shane
Hey Shane i was actually wondering about the vararam intake? I have the 04 so its not the ram air hood but i was wondering if i sould still use the Vararam intake and have better results then with my K&N.
So do you guys really think the K&N CAI is hurting my power? I mean if theres 10 more HP out there by switching to a different brand i will, but if its like 1 or 2 hp then its not worth the 300 dollars.
Old May 9, 2010 | 12:39 PM
  #110
LS12Fast4U's Avatar
Well got to the track last night. It was kind of windy about 15 to 20 mph and of course it was a head wind. But i had a best of 13.5 at 107.32. Keep in mind it was my first time at a track and it was a grudge night so the track was not prepped to its potential.
Also i know i was running well becuase all the cars out there were running about the same times i was. I raced a 2008 Mustang GT with the Roush supercharger. He had a 2.0 60 ft compared to my 2.2 but i still came back and pulled him. I beat him 13.5 to 13.6. I was at 107 and he was at 102.
Also there was a new Challenger Hemi out there with full Hotchkins suspension, bolt ons, and Drag Radials, and he had a best of 13.6.
Were at 4700 ft as well if that makes a big difference or not.
Old May 9, 2010 | 03:44 PM
  #111
RevGTO's Avatar
Pontiacerator
But i had a best of 13.5 at 107.32. Were at 4700 ft as well if that makes a big difference or not.
Uh, yeah ... given the weather stats I could find, if it was about 60*F out, your DA was 6000ft. At my location in my car, I find every 1000ft of DA is equals 1.5 sec in et and about 1 mph. I used an online calculator that came up with 12.47 @116 corrected to sea level. That calculated trap speed might be excessive, but no question your numbers would otherwise be deep in the 12's and 11x mph.
Old May 9, 2010 | 04:16 PM
  #112
LS12Fast4U's Avatar
So from the sounds of it i need to get my *** out there on a good da day.
Old May 9, 2010 | 05:19 PM
  #113
kinglt-1's Avatar
4700 feet makes bit of difference... your car has low 12's in it with good air easy.
Old May 9, 2010 | 07:11 PM
  #114
LS12Fast4U's Avatar
So the cam definitely made a difference. God i want some heads now!!!
Old May 26, 2010 | 11:51 PM
  #115
Sweet_SS's Avatar
I think the point of this cam was missed in this thread. This is a blower cam. It was designed to be used with stock exhaust ect, however with forced induction, it really doesn't matter. That's why with the TR224 and higher cams are making more power...n/a v. boost cam. This cam being 219/230 is meant to increase exhaust while decreasing intake to help spool up a S/C or Turbo(s). I myself am about to purchase this cam, but I'm going to boost the car. If I was going to keep the car n/a, I would most definately choose a different cam. I'm glad you saw some good gains, because the car won't see any boost for minute...need funds. It sounds like the car will still make decent power until then.
Old May 27, 2010 | 11:54 AM
  #116
redracer1's Avatar
yes & no..but I see your point. the point of the cam imo, is for a car/truck to make more power and work well with stock exhaust and pass smog. and with the AFR 205's which have a c.a.r.b # increase power even further. now if you want to increase power further it'll take boost as well...say a P1 which I believe has a c.a.r.b. # also, I think.lol.. So it's a well rounded cam from a cam only to h/c to h/c/fi. it also works off idle to 6800 and is very street freindly but be a monster at the track. I am thinking like you tho for sure but with other mod's like LT's cut outs etc you can mod your way outa what is a stealthy way to make power. why else would TR call it a cheatr cam
Old May 27, 2010 | 08:09 PM
  #117
96 WS6's Avatar
Originally Posted by big reg
I am looking at this cam for my CTS-V. I will be running it with the stock manifolds which are less restrictive than the fbody manifolds and RT cats which are good for 10-15 hp. I want it sound like a cb/I car only when I pound the local m3 and rs4/s4 crowd. I am definately interested in seeing your results.
I'm in the same boat as you with my 04 cts-v. I'm doing high flow cats, stock everything else, with a dyno tune and cam. By the way, I was looking at the random techs... 750 for high flows just because they are bolt-in? No thanks. There are some guys called TrueBendz that I have been in contact with and they are putting together a group buy for bolt in catcos for the cts-v. Way less expensive.
When I emailed Patrick about my cam I was under the impression that the TR224 would pass smog easily if it was tuned right. He said it was too beefy to pass smog and recommended his 222/222 with EPS lobes. He said I would gain 20-25 rwhp over the ls6 cam. Honestly, 20-25 rwhp is not even worth the trouble to me I would rather squeeze. Well I'm gonna squeeze anyway but that's beside the point. What can I honestly expect with a smog legal cam on an otherwise stock ls6?
Old May 27, 2010 | 09:38 PM
  #118
LS12Fast4U's Avatar
Even if you go with the Cheater V3 cam as i did you will need a tune. My car was running very lean after the cam install. So dont blow your car up and get a tune whatever you decide.
Also smog wise, i had to get my car tested this month and it passed easily.
I think im going to be swapping to a FAST intake with the Vararam CAI as well.
Old May 30, 2010 | 03:37 PM
  #119
BlackNiteWS6's Avatar
I would expect more of a gain since the GT2-3 cam makes about 35 to 40 rwhp.
My old Comp. 216/220 cam gave me about 35 to 40 whp.
Old May 30, 2010 | 03:55 PM
  #120
LS12Fast4U's Avatar
I was hoping for a little more as well. But each car and engine is a little different. Another Ls1 gto could gain 50 hp from it. Depends on set up. Also the only thing i have on the intake side is a K&N CAI. Its still the stock TB and LS6 intake. I think with an aftermarket intake and tb it will be 375 380 hp.
