122K LS1 Cam on stock lifters?
Hi All,
I have researched and seem to have found plenty of examples of high mileage H/C ls1’s however I have not seen too many high mileage cam only on stock lifters….
What do you all think? I would like to keep the price down and not pull the heads off. Do you think the average well maintained LS1 with over 120K on it will handle a moderate to mild cam on the stock lifters? Since my oil pan is leaking a little oil, I might change out the rod bolts while I change the gasket as well….
I plan to change all the other standard items, pushrods, springs, oil pump, timing chain.
Any help is appreciated
Thanks,
Thanks,
I think it would be a very good idea to spend the little extra money and time while you are doing the work now rather then having to go back and do it all in a couple thousand miles after your cam swap. Remember those lifters have 122,000 miles on them and they are over 11 years old.
i would suggest the following for any cam swap for good measure, smooth operation, confidence in your new found power:
LS2 Timing Chain
compcams lifters or LS7 lifters
valve spring upgrade to match your cam
Oil pump, more flow higher pressure (i.e LS6 ported)
pushrods!!!! to match your cam
i feel these are all highly recommended items when going up on a cam, and if you got the money swap the heads while you got them off to change the lifters. and if you do that might as well go full roller too
but i would change those 5 things if you plan on beating on you motor....and if you say you wont then you are a LIAR!!!!!!!!!!!!!!!!!!!!!
LS2 Timing Chain
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Well, this is not what I wanted to hear but thanks guys.... I am now thinking I will save a little more for a set of heads or look for a good deal on some used 243's if I'm pulling off the stockers anyway for the lifters.... I assume I should go with new lifter trays as well…
yeah i believe any 243 head will bolt right on a 99 block. i think the only difference was on pre 99 heads the valve covers were peremiter bolts and not the center bolt like you have.
correct me if im wrong guys!
i actually thought about puttin a MS4 or the polluter cam in on my stock lifters.
i jus ticked 113k on the odo..but im jus gonna save and get one of TSPs head/cam packages cause they're rather cheap
and as stated i would go on and swap heads while you got them off..no sense in buyin gaskets twice..and then doin the work all over again.
good luck and lemme know how it comes out
Thanks again everyone, I am thinking I will most keep a look out for a deal on a set of used 243's and get a custom cam or just get a TSP 5.3 Torquer combo....
