224 228 112 Cam
224 228 112 Cam
Well my ute has just ran over 100,000kms its a 2002 VU SS ute i am over in OZ.
Wondering how many kms and with mods does the LS1 motors hold out to????
I am wanting to be adding a few more Killer Wasps to the current set up.
Ute has 1/34 pacemaker headers, 2.5 exhaust OTRCAI, 3.9 gears
What is gonna go in!
Any input on anything below would be helpful.
224 224 112 cam
Dual springs, titanium retainers, new seals, locks, bases
Moly pushrods
LS1 heads cncd or Trickflow heads not sure
Comp 850 lifters
YellaTerra Rockers
New head gaskets GM MLS
ARP head bolts
25% UDP
Need some help guys as the camshafts are much more aggressive in the US
The ute is weekend driven, will see the qtr mile for times!!!!
cheers
224 224 112 cam
Moly pushrods
Comp 850 lifters
YellaTerra Rockers
ARP head bolts
25% UDP
cheers
consider a thunder racing 224 cam,TR224.check out engine power systems,EPS cams.stock #243s will make 400 hp with a TSP 228 cam.I like the trick flow cast 220cc heads,for $1700.vengeance racing offers a great head/cam combo,TFS heads/cam/push rods/gaskets/bolts.what intake are using.
Cam choice is leaning 224 224 or even a 228 232 or 228 228
Compression ratio still deciding?
I would like good power curve but also heavier top end wouldnt hurt
Trick flow 220c heads would be plenty as i may even go 383 in the next few yrs
My intake is an OTRCAI Maffless
But a 90mm nick williams throttle body could be needed for engine to breath
or FAST combo
or FAST combo
VUSS very interested in this setup. Let me know how it goes. My LS1 just turned 111k mi & I'm awaiting a 12-bolt. And was looking for a decent 420-440hp setup that won't my stock bottom end until there's $ for a new motor. 224 226 112lsa w/ a set of AFR or TFS 205s or even just a ported #243 to save some cash was what i'm leaning towards. Mods in sig. Will be adding a FAST & a higher stall before the H/C swap.
from oz
Hey mate,
it's only barely broken in at those kms.
Have a look at this thread from home:
http://www.ls1.com.au/forum/showthread.php?t=136106
cheers,
Gav
cheers,
Gav
224 224 112 cam
Moly pushrods
Comp 850 lifters
YellaTerra Rockers
ARP head bolts
25% UDP
cheers
224 224 112 cam
Moly pushrods
Comp 850 lifters
YellaTerra Rockers
ARP head bolts
25% UDP
cheers
Hey gav mate
I have been reading this the bloke posted it up few days later, not to sure on a charger
I would prefer a dirty NA stroker
Suburban Street Menace
Russo or Marranos are gonna be doin open heart eventually
Till then till i know what i wanna do and DO IT!
mick
mick
This is my new situation
4" Eagle 4030 crankshaft
Scat H beam conrods
Clevllite race series bearings
Forged pistons & rings to suit apllication
Balanced
Modified oil pump & oil system
228 232 camshaft
JP double row timing chain
Trick Flow Heads or LS1 cnc Higgins
Double valve springs
Comp 850 lifters
Moly Pushrods
Yella terra Rockers
25% UDP
FAST 90mm Manifold
Nick Williams TB
ARP head bolts
Cometic head gaskets
New Clutch to suit, salve, spigots
Then i will stop the mods
Scat H beam conrods
Balanced
228 232 camshaft
Comp 850 lifters
Moly Pushrods
Yella terra Rockers
25% UDP
FAST 90mm Manifold
Nick Williams TB
ARP head bolts
well if ur goin for cubes i recon u can go a bigger stick.
u goin to use the standard block?
go trickflows or get a set of 243 castings and get those worked.
go marranos. Also have a think whether an ls3 + cam + head work might suit
u as well. Cubes are nice but in oz can be pretty pricey.
cheers,
gav
cheers,
gav
Scat H beam conrods
Balanced
228 232 camshaft
Comp 850 lifters
Moly Pushrods
Yella terra Rockers
25% UDP
FAST 90mm Manifold
Nick Williams TB
ARP head bolts
Scat H beam conrods
Balanced
228 232 camshaft
Comp 850 lifters
Moly Pushrods
Yella terra Rockers
25% UDP
FAST 90mm Manifold
Nick Williams TB
ARP head bolts
Vengance combo sounds good!!!
Wonder what the Customs and import duty would slug me???
I have thought long about a ls3 + cam install is about 15k done and dusted
But leaning towards keeping my motor had it for 4 yrs and it dosnt burn oil i have put 40,000kms on it now 100,000kms, oil done ever 5000kms with 10/40 Nulon. Radiator done soon as i got it never driven in congested traffic only high way or cold night thrashes.
Motor seems to just be run in.
Yes i will keep my block get it tested
