new cam what heads???
i just got my cam today and its a comp cam 244 242 with a 612 610 lift 112 LSA ...and i want some heads but budget isnt that high so i was thinking just some stock or ported 243 heads....its a 00 LS1 auto with stage 2 built 4l60e tranny 3200 stall and full exhaust....what heads are good for my set up but wont kill my budget?...any opinions would help thanks
LS1 Tech Administrator
Unless you plan on flycutting your pistons, you don't have room to go with aftermarket heads with larger valves. I would recommend stock 243 heads with upgraded springs or Stage 1 CNC ported 243 heads with stock valve sizes. Oh, and you better have an excellent tuner. That cam is pretty healthy.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
LS1Tech Premium Sponsor
I'd say you'd be better off, as far as piston to valve clearance goes, with the aftermarket castings actually. They actually give you a few thou better clearance than a stock valved LS6 head will, and you'll need all the room you can get with that one!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
This is a true statement for many aftermarket castings, but not all. Whatever head you choose, make sure the valve free drop is 0.150" or greater. Anything less and you will be too tight on piston to valve clearance with that cam. Check with the head mfr. before you buy. Get that dimension before you spend your cash. TSP has this info for all of their PRC heads and probably all the other brand heads they sell.
__________________
For the best piston to valve clearance (which is going to be a concern with flat-top pistons and that camshaft), the aftermarket casings such as the PRC 215's and TFS 215's will be your best bet!
__________________
That cam isnt even in the ballpark for being correct. The car will make more power and be much more fun to drive with a smaller cam. Id go with something more in the 228/234 myself, but Im always conservative on duration, but I love lift!!!. Ive had a few cams that were too big and it sucked. I always error small.
