Where is my oil going?
There is smoke coming out under hard acceleration, looks black but not sure. It doesnt smoke at idle or smell like oil. I have check a couple plugs, number 1 and number 7, look brown like normal, no oil.
I was thinking valve seals. Let me know
I am going to check my catch can and lines to see what is in them when I get home tonight.
I took off my catch can, nothing in it.
I have dual Saikou Michi catch cans setup on there, intake/TB is bone dry, but I'm missing a quart every 1000 as well...not smoking on idle or normal driving, only at WOT, but its not blueish like oil....so, I picked up some valve seals to install and see if that fixes it as well as going to put some more thread sealer on my rocker bolts. I'll try and get to them this weekend and get back with you.
Thanks,
Cody B.
The Saikou Michi has the best design like an A/C accumulator. Where the inlet port goes almost all the way to the bottom, and the outlet ( to the PCV ) is at the top. Therfore Oil won't get sucked back in.
Just an FYI...
Cody B.
Fyi, my buddies followed me to the track and it only blew black smoke out just before shifting which I believe is normal. It does not blow any blue smoke at any time.
