Porting your own oil pump
There are some cases where I've actually seen a high flow pump cause more issues than it solves. With really high flow it's possible to pump enough oil to the top end of the motor to start sucking air. Not exactly the best way to create oil pressure.
I really doubt this. The Melling 10296 pumps 18% more than stock and I don't think porting a stocker will make it flow more than a 10296. And lots of respected builders use the 10296. HKE just put one in the build going in my car.....
There were some bearing failures in LS1 vettes that were road raced but it was from oil sloshing and exposing the pickup to air, not by pumping all the oil to the top of the motor.... One of the things that these guys started doing was running 20-w50 (Bondurant Driving School) that in theory stays up top longer and drains back into the pan slower.... Specially designed oil pans also help with this problem on road race cars.
And I have been running a high flow 10296 for 35K now no problems.....
This is myth........
Be conservative about how much material you remove and avoid the area the o-ring seats and you should be fine.
your not going to be opening up the area by much so it shouldnt oil starve anything or even get close to it
you also need to shim it when you in there if you are going to port(blend) yourself.
