tech hook up
Old Aug 7, 2010 | 12:09 PM
chevy_stang88's Avatar
Default tech hook up
i really need some help here im having a really bad problem i cant seem to hook up my new autometer tech i did alot of looking but just cant seem to find out where to hook it up if someone could help me out this would be great
PICS would be a great help thanks again guys
Old Aug 7, 2010 | 12:16 PM
25thhawk's Avatar
What year is your car? I hooked mine up at the pcm. under the hood, pass side by the firewall. I am not sure if different years use a different pin for the signal wire thats why I asked.
Old Aug 7, 2010 | 12:18 PM
its a 2002 ws6 trans am
Old Aug 7, 2010 | 12:26 PM
25thhawk's Avatar
The signal wire is pin 35 in the pcm, it is a white wire. There is a detailed writeup on how to install it at www.installuniversity.com. Look under installation instruction. Then scroll down to the transmission section. Then open the one labeled Matt Harlan Shift Lite. That will have all the info you need. Enjoy.
Ryan
Old Aug 7, 2010 | 12:34 PM
that works thanks alot man
25thhawk's Avatar
anytime
Old Aug 7, 2010 | 01:16 PM
FireTA98's Avatar
^^^^x1 Registered User
Let us know what was the outcome.
Old Aug 7, 2010 | 03:49 PM
That write up worked good it's all done thanks for ur help
