Ported LS6 Oil pump or Standard?
Key thing to remember and worry about is not to pinch the O ring.
http://www.brphotrods.com/mm5/mercha...Category_Code=
http://sdparts.com/details/gm-perfor...parts/17801830
because when it's pumped all that oil to the top you need more oil in the pan or it pumps air. Yea, this sounds like a good idea
look, if you want to increase the pressure just a little bit that's fine. Just put in .060 shim behind the spring and you'll have 40 lbs idle and 60 lbs crusing. That's plenty for any LS engine to live with.
oh, and that stock oil pump you have is a LS6 pump
