TR230 in a 6.0 LQ9
I'm not sure how a 228/232 in a 6.0L couldn't make all the TQ you wanted down low, unless it's just lack of compression causing the soggy feeling.. With 317's milled .020 on an LQ9 you're barely eclipsing 10.5:1 compression.
Your sig said you're working on doing your own tuning. Do you have a file to post? It could be an issue with your tune. That setup shouldn't have any problems blowing your skirt up below 4K IMO.
There is a LOT more to tuning than just setting the A/F to 13.0 and calling it a day. A novice tuner can definitely leave a ton on the table for the potential of a good setup. Post your tune file when you get a chance.
You should really consider more compression, guys here are using upwards of 11:1 with 91 and a good tune. It will help out the bottom a lot, and gas mileage will get better (slightly). I'm thinking theres a lot of work (and power) left in your tune as well. Engines don't care exactly what # afr they have, they just want the one that works. And its not linear all the way across either. Most want a bit more fuel around peak torque, while peak hp will want something slightly leaner than pk torque.
. Either way I am a mechanic and so all the work so labor is not an issue its just I dont know how to pick a damn combo!
. Either way I am a mechanic and so all the work so labor is not an issue its just I dont know how to pick a damn combo!^^^thats how you make torque in an M6. That and 4.10s or higher. Also, LTs take away torque. Consider (hear me out) the Hedman Tork-Step header. Its a 1 5/8 primary that steps to 1 3/4 into a 3 inch collector. The midrange on these is insane. I swapped to a full 1 3/4 header and I felt a huge drop in mid-range torque and throttle response.
For 3-4k+ and up power: LTs, big exhaust (3 inch+), LS6/FAST intake, 224+ cam
For torque: Mid length or Hedman Tork-step headers, smaller exhaust pipes (2 1/2), 220 or smaller cam, ls1/truck intake.
Here Is my current Tune
