What's the proper clearance Piston-Head??
Old Sep 21, 2010 | 08:14 PM
bugy's Avatar
Question What's the proper clearance Piston-Head??
hey, I got a 6.0L LQ9, Piston, rods and crankshaft is stock, these are cam specs: lobe lift exh=367 int=363 duration @ .050 int=231 exh=239 lobe separation=113.
RC=11:1 converter=3000 RPM
this is carburated: holley vacuum 675
heads 243 casting, valve train full roller.
The clearance piston-head in my engine is .035" but I dont want to take any risk, should I make it bigger or is it ok???
Old Sep 22, 2010 | 09:24 AM
SOMbitch's Avatar
It is generally recommended to have minimums of .080 on the intake and.100 on the exhaust for a street car... You may want to look into flycutting...
Old Sep 22, 2010 | 09:29 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Are you actually asking about piston to head clearance, or piston to valve?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 22, 2010 | 10:53 AM
bugy's Avatar
mmm I'm actually asking about piston-head clearance...
Old Sep 22, 2010 | 11:04 AM
Piston to head (basically the same as quench) is ideal around .035-.040" on these engines.
__________________
Old Sep 24, 2010 | 01:34 PM
bugy's Avatar
more opinions??
anybody???
please what do you think??
Old Sep 24, 2010 | 03:34 PM
SOMbitch's Avatar
I misread your question.... Listen to Matt^^^^
Quench on my motor is about .043.....
Old Sep 24, 2010 | 03:43 PM
BarneyMobile's Avatar
I run a .034 quench on my forged 347 with out issuse.
Old Sep 26, 2010 | 10:26 PM
Bo White's Avatar
Ive seen as tight as .027 but it was by previous builders mistake and was lucky. .035" is the minimum target clearance to shoot for. I usually zero the piston with the deck of the block and the headgasket thickness be the amount I want.
