Help a newbie understand cams....
Old Sep 25, 2010 | 06:44 AM
taws6's Avatar
Default Help a newbie understand cams....
Hi
I'm going to be buying a 02 C5Z early next year, and I'm already considering some mods for it!
I'm looking for improved acceleration for around the track, power under the curve, between 2000 and 5000 rpm. I hear a small cam is best for this range of increased power.
Sure the Z will be better than I can cope with, but I'm always looking at the next step....
I'm considering 1:8 roller rockers so I don't have to tear into the internals, and see they could offer an increase from around .550 lift to .580 , an additional 0.030" of lift at both the intake and exhaust valves.
The piston to valve clearance gets tight with a 1:85 on the 02 + LS6, so 1:8 is as high as I'd go.
I'm hoping someone can fill in some blanks for me so I can compair the rr and the extra power in comparision to camshaft gains??
LS6 cam 204/218 duration 0.551/0.547 lift, on 117.5 LSA
LS6 + 1:8 rr ______? duration 0.580/0.575 lift?, on ____? LSA
Small cam 224/224 duration 0.551/ 0.551 lift, on 114 LSA
Medium cam 232/234 duration 0.595/ 0.598 lift, on 112 LSA
Big cam 236,240 duration 0.630/ 0.612 lift, on 111 LSA
I'm still don't have a full understand of camshaft numbers, but if someone could fill in these numbers I'm sure it would put another piece of the puzzle in place for me.
Thanks for the help
Old Sep 25, 2010 | 07:06 AM
SWEET98SS's Avatar
There is a stickie at the top of the internal section that explains most of this. check it out
Old Sep 25, 2010 | 09:19 AM
Damian's Avatar
LSX Mechanic
https://ls1tech.com/forums/showthrea...referrerid=183
Old Sep 25, 2010 | 10:52 AM
taws6's Avatar
Thanks for the link and reference, but most of that info just goes a little over my head, even though I've read it numerous times...
I 'Think' I've calculated the lift (in red), but can't see how to calculate the intake and exhaust figures for the LS6 with 1:8 rr.......
Old Sep 25, 2010 | 10:10 PM
garygnu's Avatar
stay away from 1.8 rocker ratios.get a custom cam from EPS cams and good springs.or try a torquey truck lsr compcam ,54-455-11.
Old Sep 26, 2010 | 08:20 AM
Slash8915's Avatar
Get a 224r or 228r. Both great for power all around.
Old Sep 27, 2010 | 03:00 PM
taws6's Avatar
Thanks for your replys.
I know a cam would be a better bang for the buck, but the 1:8 rr would be much easier to install.....
Can anyone fill in the missing figures above???
Thanks for the help
Old Sep 27, 2010 | 03:14 PM
TooLateVTEC's Avatar
The duration isnt going to change a whole lot. It will increase, but I dont think it will be anything note worthy.
The way your talking in your posts, I dont think your going to get the kind of power you want from a rocker arm swap, IMO.
I could be wrong.
Old Sep 27, 2010 | 04:10 PM
SOMbitch's Avatar
RR is not worth 10HP I bet..... Bite the bullet and cam it....
Old Sep 29, 2010 | 02:34 PM
taws6's Avatar
Okay, thanks for all your replys.
Like you say SOM, I guess I'll have to bite the bullet n' cam it if I want more...
Cheers for the help
Paul
Old Sep 29, 2010 | 04:57 PM
Unertl42's Avatar
to answer your duration question
all you do is take the stock #, divide it by the stock rocker ratio (1.7), and then multiply that number by 1.8
that will give you the difference between 1.7 and 1.8 rocker arms
I agree with the guys above, do a cam swap, if you do your research, you'll be more than happy. Don't just listen to guys that say "buy this cam, its better than this other one, blah, blah, blah..." Do some research in the dyno section, there are a lot of good visuals there. The biggest thing, set a goal for the car, that way you have something to work towards. Just my $.02 though.
Austin
Old Oct 1, 2010 | 07:32 AM
taws6's Avatar
thanks, but that just sounds too easy!
So the figures would look something like this??
LS6 + 1:8 rr 216/230 duration 0.580/0.575 lift?, on ____? LSA
That would make the exhaust duration longer than the small cam, is that right??
Old Oct 1, 2010 | 07:39 AM
triche's Avatar
I did it big
It rides great. Its all in the tune. 235/240 .600+ lift, 111 LSA
Turn your speaker up, you can barely hear it in the video. Go to 28 sec in.
Old Oct 1, 2010 | 05:28 PM
garygnu's Avatar
look at a tsp 224r cam kit.I feel the tr224 mite make a little more power.get some compcam trunnion bearings for the stock rockers.
