243 heads are they the same all years?
Old Sep 26, 2010 | 07:22 AM
jman54002's Avatar
Default 243 heads are they the same all years?
Hey guys are 243 heads, are they the same on all years...The reason I ask is because my 08 Avalanche has them on a 5.3 engine, are they the same? thanks.
Old Sep 26, 2010 | 08:14 AM
BaddBird's Avatar
Pretty much the same casting but they don't have the light weight valves like the Ls6 243s.
Old Sep 26, 2010 | 08:16 AM
Slash8915's Avatar
I think you're talking about the sodium filled valves.
disc0monkey's Avatar
no i saw a post from some1 saying if there a V mark above one of the exhaust ports its the better "revised" casting. being a 08 you should be well within this margin.
while you don't have the lighter valves they don't make much difference on a stock 5.3 or LS1 setup. but can be easily installed
Old Sep 26, 2010 | 08:19 AM
BaddBird's Avatar
Yeah sodium filled exhaust and hollow intake. They are lighter then the non Ls6 243 valves.
Old Sep 26, 2010 | 08:26 AM
BaddBird's Avatar
The casting mark is more of a triangle. My 243s that came from a 06 Ls4 Gxp have these casting marks. They still have the smaller combustion chamber and they flow better then the Ls1 heads. More compression and better flow will make a difference.
Old Sep 26, 2010 | 10:17 AM
brokenfly's Avatar
Old Sep 26, 2010 | 11:44 AM
i might have said this wrong i was specifically talking about the lighter weight valves not the heads.
Old Sep 26, 2010 | 05:13 PM
jman54002's Avatar
thanks for the input...so a 243 is a 243 all the time. except for the light with valves in the ls6 243 heads. but the years makes no different in the camber size?
Old Sep 26, 2010 | 05:20 PM
blk/slvr02ss's Avatar
They say the ones w/ the triangle under the spark plug hole are good for 6-10 hp more because they are semi-permament mold casting but i have seen that same triangle on 241's also.
Old Sep 26, 2010 | 06:10 PM
BaddBird's Avatar
I have read 10-12hp I think it is more internet BS than anything.
