How many cubes bigger can you go with a 346CI ?
I blew the motor in my 01Z and going to do a rebuild. Wondering if I wanted to bore over the block what is the biggest a builder can safely go with a Stock LS6 block? Do any of the vendors sell a package I could purchase for my builder with all the parts ie crank, rods, pistons, seals, bearings, etc....
LS1Tech Premium Sponsor
http://www.texas-speed.com/shop/item...d=884&catid=88
They make larger stroke cranks and correlating piston sets for that block so you could go 395ish cubic inches, but honestly if I was going to spend the extra money on a setup like that, I'd go with a different block and make it worth my time and effort!
383ci has been the long tested stand-by combo for that block, and works pretty well!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
