crank wont turn, standard bearing too small
I am refreshing my motor and when I Mic'd my crank it checked out. I went to the parts store and bought sealed power standard bearings and the bearings are too small causing the crank to not turn. No connecting rods attached just the mains snugged. Wtf is up with this?
LS1Tech Premium Sponsor
Check to make sure they are the correct bearing first. Also, if you had your crank machined, are you sure it was done properly and is perfectly round?
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I got the bearings from oreilly autoparts and the part number is 7298ma. I checked the part number and its correct for ls1 engines in a standard size. The crank came out of the same block I am putting it into . All the mains check out and with the caps off the crank spins freely
So it was a working shortblock, the crank wasn't turned, and now it won't spin with new bearings? Are you sure you didn't mix up the main caps, and have them all turned the right way?
You need to seat the thrust bearing. Snug it down and give it a few good hits with a rubber mallet on the front of the crank driving it toward the rear of the block, and then a few hits on the back of the crank driving it toward the front of the block. You'll know when its seated because it will spin like butter. This is "seating the thrust bearing"
Another DIY engine build destined for a "why is my engine knocking???????" thread...
As for your second statement, you can gtfo! If I didn't come on here then there would be s thread like that. This is just a get by motor until my 418 is done.
Does it stop turning after the first main is bolted down or are you bolting all of them down then trying to turn the crank?
As you probably already know you should turn the crank over each time you torque something down, main caps/rod caps, so you know when you reach a problem.
I am assuming the bearings you got are actually what they say they are?
No reason to puff up and tell us what motor you are going to be building next.
I did and that's why I'm here just asking a couple of questions you dumbass. Crank checks out at 2.559 and the number one main checks out at 2.550.
Bearing I.D. = 2.550"
2.559 > 2.550
Crank diameter > bearing diameter
And you're calling me a dumbass?
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
My reply just wasn't very polite, change your panties if you're offended by that.
The parts store guy probably sold him oversize bearings.
Or, perhaps they gave him the correct box, but somebody else returned that box as new but with .010" bearings in there.
__________________
