torque specs on head install
Old Oct 12, 2010 | 04:09 PM
TermnEatr's Avatar
Default torque specs on head install
what ft lbs do I install the head bolts and is it the same for the top bottom and middle bolts or is there a sequence? They are 243 ls2 heads going on a iron 370 thanks.
Old Oct 12, 2010 | 04:46 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
You using the TTY bolts or ARP?
Old Oct 12, 2010 | 04:52 PM
TermnEatr's Avatar
there arp
Old Oct 12, 2010 | 07:11 PM
TermnEatr's Avatar
anyone?
Old Oct 12, 2010 | 07:33 PM
Arc00TA's Avatar
ARP bolts are 3 steps to 75ft-lb for big ones and 25ft-lb for the small ones. I can get you the torque order in a second.
EDIT: order is
Small bolts at the top: 15, 13, 11, 12, 14
Middle bolts: 10, 3, 1, 5, 9
Bottom bolts by manifold: 7, 6, 2, 4, 8
I don't have the picture but thats out of the GM manual.
Old Oct 12, 2010 | 11:56 PM
chuckyt1's Avatar
http://www.bowlingss.com/LS1_How_To.htm
Click on Head Replacement. Near the bottom of that page where they talk about using ARP bolts.
Old Oct 13, 2010 | 06:50 AM
TermnEatr's Avatar
thanks guys
Old Oct 13, 2010 | 08:42 AM
BlackScreaminMachine's Avatar
Internet Mechanic
EDIT: order is
Correct!
I will add only this. IF you need to stop, complete a FULL pass so they are all equal TQ. So you dont chance warping the head. Had people I know in the past with Aluminum do a half pass and get caught up in something and to finish up days later and then have issue later in the summer.
Old Oct 13, 2010 | 11:00 AM
TermnEatr's Avatar
so when running through 1-15 I start at 1 and do I torque all the way to spec? Or just go through 1-15 and snug and then go back through and torque to spec?
Old Oct 13, 2010 | 11:16 AM
Arc00TA's Avatar
I got them all snugged because its a pain to do with a torque wrench, then started torquing. I also had to find a small torque wrench to hit the tiny bolts at 3 steps to 25ft-lb because my big one does not go that low. For those I ended up going 10, 20, 25.
Old Oct 13, 2010 | 01:10 PM
Internet Mechanic
You need to run the pattern one full, entire sweep. Once you get back to #1, then you step up the TQ spec, and do another complete pass, rinse, repeat for the 3rd sweep/pass. I always do one more at the same setting after letting them sit for a little while to double chk for false readings. I understand you need some oil to find false readings but another pass should good for double checking.
If I was not so fearful of the bolt holes potentially cracking if there is fluid or debris, I would be using a little oil, APR bolt lube or something to ensure perfect spec. (mind you there are different opinions on this subject, so let other people chime in).
Old Oct 13, 2010 | 07:11 PM
wickedbluess's Avatar
try ls1how2.com and go under head swap.
Old Oct 13, 2010 | 08:40 PM
brokenfly's Avatar
