New Cam Sensor, New Crank Sensor, Fuel Pressure, but Car Still Won't Start
I've tried everything I know to do short of taking the car to the dealer. The cam and crank sensor have both been replaced, the car had fuel pressure the last time it was checked, the fuel pump primes, but there's no spark. Do any of you have any ideas what else I could try before taking it to the dealer?
This all started after installing the LS6 intake. It would start after several tries before, but now does nothing. The only code I've got is for the EGR, and everything appears to be plugged in correctly. There was no power to the coilpack connector, either, while trying to start the car.
Thanks,
Josh
Thanks,
Josh
Spent over $100 on a new cam and crank sensor, and a $14 ignition relay fixed the problem. I'm sure glad it's running, though. Thanks so much for the suggestion, H8 2LUZ. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Josh
Josh
