PP stg2 heads and TR224 Dyno #'s by Nitro Dave's
hi,
i just added a Patriot 5.3 stg 2 heads, Pacesetter headers, LS6 intake, and had the car tuned at Nitro Dave's...
1- a month ago the base numbers were 301.6 hp, 317 tq, on this run car only had a lid and a cutout..car is a 99 SS M6 with stock 3.42 gears
2- same day as #1 i added a TR224 112 cam with no other changes other than the valvetrain, pushrods, TR ls6 oil pum, and timing chain, and dynoed 323 hp and 327 tq..
3- last weekend, i had Patriot stg 2 5.3 heads, Pacesetter headers, LS6 intake, and tunning at Nitro-Dave's, and the numbers were 398 hp, 388 tq
with this run, i checked the tire pressure and saw that one of the rear tires had a little less than 20 psi air, so if it was 30 it might have hit 400 hp
i will try to post a graph if i can get a scanner,
Dave, if your reading this, can you please post the dyno graph
soon i will add a ported TB (don't know which one, Bauer, Jantzer, or Thunderracing TB) and an ASP pully,
do you guys think i can pick around 10 to 15 hp with the TB and pully?
Cammin BeaSSt, that was with the ls1 intake and stock exhaust manifolds
Kit (KGSloan) i see that you are from Stillwater/Tulsa, i saw one time in Stillwater a very nice SOM SS with polished Tourq Thrust wheels, is that your car?
Gotcha, I would have still expected HIGH 340s to 350s. The manifolds were the big restriction, the intake is worth 5 or 10 tops...
Congrats on your gains. Go for the TB, ASP. That alone should get you 400rwhp through your 10bolt and 3:42s....
btw.. was those numbers thru the cutout or the exhaust? what exhaust are you running?
gomer, all the runs were through the cut out, i have a stock exhasut with a magna flow muffler, it sounds good too with the cut out closed
ne14a6t9, i don't know what other H/C cars put there, but i'll ask Dave,
Chris ARE 360, final numbers were with Pacesetter long tubes, ORY, and by stock exhaust i meant a stock cat back with a magnaflow muffler and an open cut out,
thank you everybody,
Abdulla
Abdulla
Originally Posted by ne14a6t9
numbers arent bad if it was 1999. What do other H/C cars pull on that dyno
