can i bore a 98 ls1 out .10
need to stuff some new pistons in and i remember reading somewhere u can only go .07. is this true or am i stuck with .05 and more expensive pistons then i need. thanks
Really,and I though that 3.998 bore would work just fine.
Your opening up the cylinder by thousandths (.005) not hundreds (.05) but,if you insist give it a try...just kidding.
If I were you the .005 is the maximum I would go on a 98 block. There is no benefit going larger...it doesn't even equate to one cubic inch...good luck.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
