best cam for prc 2.5 5.3 heads
Old 01-21-2011, 08:54 AM
rob00ss's Avatar
Default best cam for prc 2.5 5.3 heads
Wondering what cam is best matched with these heads for the most power
Old 01-21-2011, 09:33 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
It really depends what you are looking for out of the car and the cam. Are you looking for a big lopey cam, or something with some more midrange and low end? Is your car auto or manual? What kind of car is it? Give us some more information and it would be a bit easier to help you out.
Old 01-21-2011, 10:58 AM
rob00ss's Avatar
Looking for something alittle more lopey car has a can in it now and loped pretty good with the stock heads but now seems like it hardly does. Car is a manual 2000 camaro ss and trying to debate if it would be worth time and money to even change it
Old 01-21-2011, 11:02 AM
rob00ss's Avatar
Don't have exact numbers with me but cam is around 230/236 578/598 111.6
Old 01-21-2011, 11:09 AM
Hmmm, I would expect that cam to lope pretty hard just looking at the specs. Usually 111 LSA cams have a noticeable idle. Do you already have the heads? If so were they milled? We do have a couple cams that are a bit larger but I would want to make sure you have enough clearance for them.
Old 01-21-2011, 11:36 AM
SOMbitch's Avatar
My 230/234 111 cam sounded like a popcorn at 950rpm idle with those heads lol.
Old 01-21-2011, 12:26 PM
rob00ss's Avatar
No the heads are not milled. And yes I don't understand why it loped hard with stock heads and now it hardly does after I put the heads on. Only other thing I changed was put a flowmaster exhaust on it would that have anything to do with it cause I heard they suck and I can't think of any reason it changed so much
Old 01-21-2011, 08:57 PM
Giddswat's Avatar
I don`t know about the most power, but the 228r 112lsa is a nice match.
Good power, Good street manners, and a nice lope to it.
Old 01-21-2011, 09:40 PM
Shadow1999's Avatar
Off the shelf a 228R, Futral F10/11 are good choices. All depends on what you want to do with your car as John Janz said. DD, auto cross, drag!? Personally I am going with a F10 when the money is available.
Quick Reply: best cam for prc 2.5 5.3 heads
