Pro's & Con's of .650+ lift cams for street use
I just want to know what are the pro's and con's of large lift cams (.650+) for street use. Is it worth it running this much lift or is around the .600-.650 the most lift for the street?
Any help would be great, a little new to the art of cam's and want to learn
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I think you really need to understand valve events before looking at just 1 point out of a cam selection. The puzzle pieces will probably fit, but it won't be ideal most likely. Get my drift?
What are you wanting the car to do?
Is this a nitrous setup? S/C or Turbo?
Heads?
Manual/Auto transmission?
gearing?
Summit racing stickers?
Hard to give you nothing but con's if you don't let us know what you are wanting to achieve. Maybe you are wanting a solid roller setup. It's hard to say. Give us some plans and background info on the build.
Heads?
gearing?
Well hear is what I am thinking about doing
220 as cast trick flow heads, as they come with 1.7 rockers, switching them out for some 1.8 rockers, fly cutting the pistons and pushing a .600 lift to around the .650-.660 mark. Thinking of having the combo around the 11.1 to 11.5 area
The plan later on is FI, be it Procharger or PD, I am undecided. When that time comes I will change back to the 1.7 rockers if the lift is too great
Its a M6 and the gearing at the moment is 3.45, however am I open to suggestions on the best diff gears
Wont be running any summit racing stickers, but if this increases HP I'm all for it
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
the only benefit you will get is slightly more power,but under 1 condition.And thats if the heads can support it.Sure you can do it,but will the heads flow any better at 650 lift vs 600.Take a look at the as cast TFS heads,and try to find some flow numbers at .650 lift.I am pretty sure they flow less at .650 than they do at .600.So in that case not only would it put unnecessary stress on the valvetrain,it will even cost u some power.Running high lift is for the big heads that can support those lifts with much added flow
Unless your bracket racing or its a race car there is little point in running lifts like that unless you like spending a lot more money for small gains with increased maintenance.
I have a big .650 lift cam in my current setup.... It only sees street duty 2x to 3x a week. Already changing valvesprings after 2000 street miles... Power is awesome but the routine maintenance and cost of maintenance is not fun at all.
It should help guys the think what thouse cfm numbers are, and how a bench is getting them. And how much different that is, then what happens in a running engine.
gtorep, whats springs you running? Xbling
well that might be true if there was some law of physics that expressed how adding cfm on a flowbench will always make more power on a running engine. To bad thats not true, and easy to disprove. Its like using the hardness of metal as the only variably in its raw strength. Thats not going to work out good.
Which of Ed's cams are you using now? Mine is a modified Hellion 244/255 .650/.650 on a 112+3
![Rock](https://ls1tech.com/forums/images/smilies2/rock.gif)
Old School Heavy
Unless you are into competitive class racing, I would avoid pushing the limits on any part of your build. Using ultra aggressive ramp rates and ultra high lift might produce small amounts of additional power but the gains will be dis-proportionate to the amount of stress introduced to the valvetrain. I say use the proven parts that have a track record of exceptional performance and durability. Street cars are a lot more fun when they are not broken.
This definition from Webster's seems appropriate here:
Definition of DIMINISHING RETURNS
1
: a rate of yield that beyond a certain point fails to increase in proportion to additional investments of labor or capital
2
: benefits that beyond a certain point fail to increase in proportion to extended efforts
1
2
