Wont start video added please help (MORE VIDEOS ADDED)
#43
i know what op is talking about my security light is on in my 02 ss, but it starts and drives fine and gives no issue. i have hp tuners and planned to turn it off, but it doesn't seem to do anything other then the light being on. i had hptuners on it and it wasn't throwing any codes but that's not to say it finally isn't working for op my vote would be vats.
#44
Other Options
There are some basic things you can do. Turn of all power accessories in the cabin. Turn the key to the on position. You should here a hum for a few seconds. This is the fuel pump. If not sound, have someone stand at the gas filler with the cap off and place their ear close to the filler. Try the same procedure.
If there is a hum, use a pressure gauge and test the pressure at the rail while cranking. If there is not you can do a voltage drop check at the pump connector. Or if you do not know how to do a voltage drop test, you could try a fuel pump relay but this gets into trial an error replacement. Last resort. Sometime the fuel pump relay is the same as another relay. You can swap them. Just look at the GM part number on the relays.
Once you eliminate if it is a fuel pump problem, move to the injectors. You can get a noid light from a parts store. It plugs into the injector harness after you disconnect the injector. Plug the light in. Have someone crank the car. It should pulse on and off. If it doesn't, something is keeping the signal from being transmitted.
This is where the security system might come into play. I am not an expert on this. I had a similiar problem and it turned out to be the crank sensor if I remember correctly. I the test is simply unplug it and try to crank the car. If it starts replace the part.
I should have started with this, but check all you sensor connectors. Most would probably on trigger a light but a couple could trigger a now start condition.
You can rent tools like a pressure gauge and injector test light from AutoZone or Advance and others. Most charge you the price and then refunde the full amount. It is call a loan a tool program.
Any of the parts store should be able to print you a diagnostic tree for a cranks but will not run condition.
Hope this helps
Hope this helps
#45
you can get a spare key through the dealer. just provide the vin# and they can have you one in a day or two. i had that done it only cost me 20-30
#46
well guy did the bypass and the good thing is that the security light went away, buy it still does the same thing turns on then right back off. The fuel pump does turn on so its not that maybe it does just need a tune (I REALLY HOPE SO)
#48
Make sure the grounds on the heads are good grounds look for all the grounds to be bolted. Go through the wiring of them w a comb. There are 3 on the DS head on the back if they are not good te car will only crank. It could
Start if it makes
Contact but die once ground is off.
Start if it makes
#49
Start if it makes
Start if it makes
#50
No, that isnt correct. The car will crank, it will fire, but dies immediately.
I have had this issue several times with customers that had new keys cut at the hardware store or home depot. I take one look at the key, ask them for the key that came with the car, and problem is solved. This car is doing EXACTLY what I see when a non VATS key is used with a VATS car.
#54
OP do what I told you to do about two or three days ago............
#57
Did more work on my car to try to start it up. Took the lid off got a rag and put gas on it put it in front of the TB, turned the key and started it right up rev up to like 3500 rpm then drop down and idle for like 6 sec and then turned off. Took the injector rails off cranked the motor and the injectors shot out gas, all the fueses are good. Does anyone have any ideas? My guess is that its a gas issue.
#58
Sounds like a fuel issue for sure. A simple fuel pressure gauge will tell you a **** load. Thread it onto the fuel rail, have someone start it, and watch the gauge. If something is a miss, check the fuel filter (hell, maybe just replace it... pretty cheap) and see if you can round up a spare fuel pump. You can usually find a used one for a decent price and being as you're in Texas you can probably find someone local that's trying to sell one. May not hurt to put a good after market one in there either. If you do the "trap door" method, you can swap a fuel pump in no time. Keep us posted on what you find. Good luck.
#59
it has a walbro 255 fuel pump in there, it does turn on when key is turn. fuel filter is good. took the fuel line off the fuel rail turned the key and it pumps out gas. so what next to do
