rod bolts...
Old Mar 14, 2011 | 12:25 AM
pozesd99''s Avatar
Default rod bolts...
So I have a 1998 camaro z28 with a reverse split cam and supporting mods with 100k miles. Getting a Lil bored so want to make more power with different heads cam and a 100 shot. Scared that my rod bolts will let go. I'm looking at the katech and arp rod bolts. Which are the ones to get and how hard to install
Old Mar 14, 2011 | 01:13 AM
99T/AMAN's Avatar
I went with katech bolts, their bolts are made by the company that makes GM's stock bolts but of course out of better material. Same weight and size, just a lot stronger. Have to loosen the k-member bolts and take the steering shaft loose and you can get the oil pan out. Just follow the directions and use the supplied lube or a really good moly lube. I used stuff my buddy got from Kurt Urban's shop, so you know it was good. Hope that helps
Old Mar 14, 2011 | 01:24 AM
pozesd99''s Avatar
Thank u very much. How much are the rod bolts and where can I find them
Old Mar 14, 2011 | 01:29 AM
98 StealthZ's Avatar
I just bought them and they where like $216 shipped and you order them directly from katech
Old Mar 14, 2011 | 01:30 AM
Make sure you spring the extra 3.00 for molly lube..
Old Mar 14, 2011 | 01:31 AM
pozesd99''s Avatar
How much can I safely spray with these bolts
Old Mar 14, 2011 | 01:34 AM
Adam86's Avatar
A lot. It's everything else that will give out first.
Old Mar 14, 2011 | 01:44 AM
pozesd99''s Avatar
Is 100k a lot of miles on these cars. I take good care of it. Should I ne fine with a 100 shot
Old Mar 14, 2011 | 02:23 AM
allout06's Avatar
From what I've read 100k miles in these cars isn't hit if the car has been taken care of, of course. Mine has 105k on it. And I'm bout to do H/C/I/tb trough out the year which u already kno lol. and 100shot is pretty standard. Just tune for it.
Old Mar 14, 2011 | 02:50 AM
you will be OK, mine currently has 170K on it and runs like a raped ape still
Old Mar 14, 2011 | 01:38 PM
Katech_Jason's Avatar
LS1TECH Sponsor
The Dow Molykote 1000 (sold separately for $2) is for titanium (LS7) rods only. Steel rods require the CMD Extreme Pressure lube #3 which is included in the kit.
Old Mar 14, 2011 | 01:40 PM
LS1TECH Sponsor
A1 Technologies makes the rod bolts for GM? Are you sure about that?
